Rad support bushings?
Searched but only found a whole cab/rad bushing set. My cab bushings are fine so don't need them.
Anybody know part #'s for just rad bushings?
I see energy suspension has some universal mounts:
http://energysuspension.com/universa...isolators.html
I might try and measure up the originals and source from this if i cannot find anything else.
In order from top to bottom it should be:
Bolt, rubber oval shaped thingy, steel sleeve, factory lock washer that is probably rusted away by now, rad support steel, large washer, bushing, large washer, truck crossmember, washer, bolt
Should and is are 2 different things also. Some trucks I've torn apart have 2 washers next to each other while some have 3 washers in the stack.
steelydan
Oct 25, 2004 10:06 PM
