Rad Support
Old Oct 19, 2010 | 06:47 AM
Trebor's Avatar
That bracket was used as the radiator support cushion mount in the 1970's.
Old Oct 20, 2010 | 12:30 AM
Trooperthorn's Avatar
Prior to `1975 even. It's like an apendix or adipose fin.
Old Oct 20, 2010 | 10:18 PM
Thiss's Avatar
Haha. Just goes to show how truly little the changed. Speaking of which I have read on a couple of other conversions that the bolts on the front of the leaf packs changed size from our 80s crews to the nineties. I put a tape on the bolt and they appears to have the same size. These guys were then cutting off the hangers and replacing, this just doesn't seem necessary. Can't the hole just be drilled out or a different sized bolt used?
Old Oct 21, 2010 | 06:33 AM
Trebor's Avatar
The front/front spring bolt size changed in 1992. When I scrapped my donor truck it had the larger mounting hole with a 1/2" bolt stuck through it. The front/rear bolts remained the same size at 1/2" in both cases.
crazzywolfie
Oct 21, 2012 06:50 PM
BILTIT
Jan 17, 2012 04:05 PM
thrashingcows
Nov 12, 2011 01:51 AM
steelydan
Oct 25, 2004 10:06 PM
