Quick auto trans removal question
Old Oct 19, 2006 | 07:39 PM
Ilikebikes's Avatar
It's ready to come out except for the shift linkages that go into the tranny. How can I remove those 2 levers? I already took out the 2 bolts that were in there, but I can't really see up there to do anything else.
Thanks! I will delete this thread when I get it out.
Old Oct 19, 2006 | 07:49 PM
JD730's Avatar
Did you get the trans you went to look at?
You don't have to remove the levers, just pry the shifter through the plastic gromet and the TV cable should pop off of the ball on the upper lever. Although you should be able to wiggle both of them off the shafts. Be careful if you pry them not to bend the shaft.
Old Oct 19, 2006 | 08:10 PM
Ilikebikes's Avatar
Just had to pry them off, thanks.
I'm going to look at it tomorrow.
Dlowkes7
Sep 21, 2010 02:58 PM
77machomopar
Feb 5, 2009 08:53 PM
AlanF
May 31, 2007 08:34 PM
howe719
Jan 18, 2007 12:18 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
