brakes locked up?
hey guys im tyring to help out a buddy of mine whos 1986 dodge, "not a diesel" 4x4 truck is having brake issues. his truck sat for about a month and then he went to go drive it but when he hit the brakes they wouldn't release and we can't figure out what would cause it, please any help would be greatly appreciated, sorry about this thread not being a diesel topic, but hopefully someone can help any ways.
first turn each wheel if possible, then open the bleed screw on each wheel, if you have pressure something is sticking in the master cyl or proportioning valve, if not the shoes stuck to the drum for some reason like rusting or a part comming off.
It's more than likely rust-build up either in the wheel cylinders holding the shoes out or rust build-up in the drum.
By any chance has the e-brake cable been depressed for parking? Cable siezed will cause that too
hey thanks for the replys, guess i should have specified that the brakes are disc, the master cylinder was just replaced a little while ago so i doubt thats the problem. but any more ideas would be appreciated. thanks
something is not allowing brakes to release. it's either hydralic or mechanical.
you can try releasing hydralic pressure. but I'd try jacking up one axle at a time first. this allows you to isolate your problem.
you didn't post if all wheels were locking up or just one wheel. a frozen caliper and/or rear wheel cylinder can do exactly what you are describing. so can the proportion valve in BMC not working.
a flex hose collapse can trap pressure too. there's all sorts of possibilities. rear brake shoes almost worn out, can lock up at end of travel. when parking brakes is applied.
losing the vacum booster should not cause lockup. your brake system should work exactly same except for increased pressure needed to operate brakes.
woops i keep failing to specify
well it is the two front brakes that are clamped on the rotors. and my buddy can drive the truck, but only with lots gas to keep it moving, they locked up on him when he was on the freeway and he braked a little to slow down, but the calipers woudn't release when he let off the brake.
that's a little better info...
with both frt's locking up, highly unlikely two calipers will lock up at some time.
now is the time to release a little hydralic pressure to see if both frt wheels release. if both wheels release, then chase down what's causing hydralics not to release.
if after you release pressure and both wheels are still locked up. then both calipers pistons are not releasing.
well it is the two front brakes that are clamped on the rotors. and my buddy can drive the truck, but only with lots gas to keep it moving, they locked up on him when he was on the freeway and he braked a little to slow down, but the calipers woudn't release when he let off the brake.Thread
