trailer brakes locked up
Old Nov 17, 2006 | 07:12 PM
chaydaddy's Avatar
Just bought electronic brake controller and hooked all the wires up. Plugged my 6 prong in to the 7 prong converter and tried to take off and the brakes are locked and i cant move the trailer. Is there something i missed or forgot to do? All lights and markers work.
Old Nov 17, 2006 | 07:49 PM
singleturnout's Avatar
had the same problem awhile back make sure the adapter says center pin aux,becuase if it dosent it is a center pin brake which will lock the brakes
Old Nov 17, 2006 | 08:45 PM
SMOKNISB's Avatar
Yeah I has the same problem and the adapter was wrong. There are serveral different ways to wire the same adapter.
Old Nov 17, 2006 | 08:53 PM
RustyJC's Avatar
Often, the trailer brake and battery charge wires are reversed in the 7-to-6 adapter. That's why your trailer brakes lock up - they have a constant +12VDC being applied from the truck's batteries through the battery charge terminal. Some adapters even have an easy provision to swap these wires. The 6-pin plug unfortunately doesn't have a standard wiring configuration that's as commonly accepted as the 7-pin flat blade (Pollack-type) connector on our trucks.
Rusty
Old Nov 17, 2006 | 09:03 PM
Adam3291's Avatar
I had the same problem with my adapter. Check to make sure all or your lights and signals are working first. My adapter had a place were the aux power and the brake wires chould be switched. My problem was actually when the adapter was put together it was rotated 1/2 way around on mine.
Old Nov 18, 2006 | 06:35 AM
Dodgezilla's Avatar
Did you try to move the trailer without the plug hooked up?
Old Nov 18, 2006 | 08:18 AM
chaydaddy's Avatar
If i unhook the plug, the trailer does move. My dad was saying something about that i have to run a wire from the fuse box back to the trailer so that the brakes will unlock. Don't really no why i would have to do that.
Old Nov 18, 2006 | 08:20 AM
RustyJC's Avatar
Have you read the posts above? They explain your problem, and no, you don't need to run any additional wires.
Rusty
Old Nov 18, 2006 | 09:36 AM
chaydaddy's Avatar
Just swapped the two wires in the adapter and it works. Lights on and the brake controller works great. Thanks for the help RustyJc
Old Nov 18, 2006 | 11:42 AM
Guardrail's Avatar
You have the wrong adapter. They make 2 different 7 to 6 pin adapters. I made the same mistake when I first started and had to get the other adapter.
Old Nov 18, 2006 | 12:49 PM
Longhorn06's Avatar
Best Advice: Put a 7 pin plug on your trailer. Most new trailers, have them, and of course all new trucks have them, save you alot of grief in the long run and cheaper than buying an adapter. I know you have already bought the adapter, but from experience the adapter will get lost at some point!
My 2 cents!
fortunate1
Jun 11, 2013 08:54 PM
tjwilliams
Oct 4, 2012 10:39 PM
C Minus
Mar 3, 2008 06:01 PM
hoghead
Jan 14, 2007 06:45 PM
wildcargo
Nov 29, 2005 04:20 AM
