Question About POD's and Washer Thickness...
Old May 1, 2008 | 08:11 PM
RSWORDS's Avatar
I have a set of POD's for my 89 and have the 7mm-9mm... Well in all my reading eveyone says to use the .020 washers to clean up the injectors some and get the spray pattern closer to the bowl. Is this a performance issue or just a smoke issue? The reason I ask is that for 1.25 a piece I'm wondering if it is worth my time to have the bushing milled down to .020"
Old May 1, 2008 | 08:24 PM
Free89W350's Avatar
When they say .020 they mean to use the thick copper washers that came with them (if you bought them new). When I got mine there were 4 different sizes 2 of them were the same thickness and then there were 2 other thicknesses I measured them with a set of calipers and installed the .020. I have a slight haze when it's cold and then it seems to go away. When you say having the bushings milled what bushings are you talking about.
Old May 1, 2008 | 08:25 PM
bgilbert's Avatar
Yes if the adaptors can be milled down and remain intact, I'd say go for it. You got a sloppering injector and need all the help you can get for idle haze and overall performance. The adaptor is like .090" right?
Old May 1, 2008 | 08:38 PM
RSWORDS's Avatar
Yeah the adaptors are like .090... How much will it effect the performance?
Old May 1, 2008 | 08:40 PM
RSWORDS's Avatar
The bushings are to use 7mm injestors in th eearly non-IC trucks that have 9mm injectors. And when using th ebushings you use no washer... The bushing is the washer. Just trying to figure out if it is worth my time to have them milled down.
Old May 1, 2008 | 08:58 PM
Free89W350's Avatar
Sorry I didn't realize about the bushing. I changed over to the 7mm head due to catastrophic failure.
Old May 1, 2008 | 09:05 PM
RSWORDS's Avatar
It's all good!
Old May 1, 2008 | 09:22 PM
bgilbert's Avatar
Can be the difference in little to no idle haze to mucho idle haze, warm or cold. Especially with an auto in gear at a stop light. They're already gonna be spraying or dumping fuel all over the top of the piston, so it's best to start as close to the bowl as possible. Then after you bump up your timing you'll be glad you did even more.
For less than 10 bucks, do it. What kind of turn around time is it gonna be? Oldcool90 was gonna try to turn them down at work but I bought the POD's back from him to use in my crew before he got the chance. In my crew they are nastier at idle than my Scheid 6x16 edm's and Buddha 6x18 edm's. Could be the massive .090 adaptors vs. the .020 and .040 washers used in the other trucks.
Old May 2, 2008 | 08:47 AM
RSWORDS's Avatar
I think I'm going to run them as is right now and get a second set of adaptors to mill down so that I can get a good comparison.
Old May 2, 2008 | 02:42 PM
mhuppertz's Avatar
Anyone have a source for the .020" washers?
Old May 2, 2008 | 03:14 PM
bgilbert's Avatar
Bosch shop, possibly Cummins if the guy at the counter will look them up with no ESN, or Scheid Diesel will ship.
BILTIT
Sep 21, 2012 07:08 AM
Nicholas
May 2, 2007 05:20 AM
walexa
Oct 26, 2006 12:19 PM
Cummins4Life
May 4, 2006 08:24 AM
Katmandu
Jan 10, 2006 12:51 PM
