Nylon fuel pin washer thickness?
Old May 1, 2007 | 09:58 PM
Nicholas's Avatar
What thickness is everyone grinding their nylon fuel pin washers down to? What seems to be the limit on this modification? I ground mine down to 0.090". But, it still looks like it could be ground down a bit more to 0.085" to 0.080" or so, judging by the tiny scribe marks on the fuel pin.
If anyone is interested, I ground down my nylon fuel pin washer using a set of digtal calipers, and a piece of plate glass w/some 320 grit silicon carbide sand paper taped down to it. I simply placed the face of the nylon washer down on to the sand paper, and began sanding material away using light pressure/even strokes. I kept sanding and checking the thickness with a set of calipers until the desired thickness is reached. Also, I measured the thickness in several locations around the washer to make sure it is not ground lopsided. Finally, I made sure to only sand from one surface. That way I have a known flat surface (unground) to base my measurements off of.
Nick Gajewski
Old May 1, 2007 | 11:38 PM
93beater's Avatar
i'd like to do it if it helps any, did you notice any diffrenece?
Old May 1, 2007 | 11:49 PM
Nicholas's Avatar
I think sanding down the washer has helped the performance of my truck. I have gained about 2-3 psi of boost. EGT's are still normal, maybe 100* degrees more at WOT. The also truck seems a bit more responsive/peppy.
Nick
Old May 2, 2007 | 05:20 AM
Free89W350's Avatar
I took .090 off of mine. I think the original thickness was around .125 or so well mine is now .062. I used calipers to measure them also.
ARbowhunter7
May 29, 2018 11:45 AM
14racing
Sep 13, 2009 10:43 AM
1985cucv
Jul 21, 2008 01:20 PM
Dean Snow
Oct 22, 2007 10:41 PM
BigWaylon
Apr 24, 2006 10:40 PM
