Do You Really Need The Nylon Washer?
Old Sep 11, 2009 | 11:08 PM
14racing's Avatar
I read somewhere about shaving the nylon washer down under diaphram to allow the fuel pin to travel further. Do you really even need the washer in there or can you just take it out?
Old Sep 11, 2009 | 11:23 PM
You can take it out, it won't hurt anything but sometime it'll defuel a little bit when it gets to the top of the pin... how it kinda curves back up at the very top of the ramp.
you can try it though, run it without and see if you can feel it drop off. if it doesn't, then don't run it
Old Sep 12, 2009 | 12:34 AM
peobryant's Avatar
I don't run one.
Old Sep 12, 2009 | 05:11 AM
Jim Lane's Avatar
I replaced my nylon washer with an o-ring, it is easier to gauge the thickness and it is a cushion if the pin hits too hard, My turbo will hit 56 PSI boost.
Jim
Old Sep 12, 2009 | 08:52 AM
crewcabxlt's Avatar
sand it down to 1/2 thickness or less.put it in with some grease on it,push throttle lever so pin pops out and rides on the cone ,push it down to mark it the see were it rides on the cone. ive seen 2 pumps were the washer was removed and the pin woul hit the main part of the cone and defuel slightly and bind a little. i think the down pressure caused the oring to leak around the pin. i like to sand it down to point of max fuel.
Old Sep 12, 2009 | 09:33 AM
RollinCoalSmoke's Avatar
I did basically the same thing crewcabxlt but kept sanding it down till half or better was gone. Then I removed it and still not to the defueling point or to the point where the pin starts to curve back the other way and binding. As I learn more about the VE i'll leave it at that point and place it seems to work good there.
Old Sep 12, 2009 | 08:46 PM
sdseva's Avatar
i just turned my pin, and when i did i noticed how much of it was going to wast because of the washer. i sanded lots of it off and the new "mark" from the pin is much longer, although i could still go more so i will prob take mine out too.
Old Sep 12, 2009 | 09:05 PM
92smokin blacky's Avatar
just take it out, I took mine out and got more top end because the fuel pin could travel down farther. Just take it out and if you need to go back, then put it back in.
Old Sep 12, 2009 | 10:09 PM
1985cucv's Avatar
mine is out if you wanna keep it in sand it down a little more than half like stated
Old Sep 12, 2009 | 11:52 PM
14racing's Avatar
I think ill just take it out and see what happens. Does it make a pretty noticeable difference? I already have the pin set to the deep side.
Old Sep 13, 2009 | 07:22 AM
14racing I don't think I noticed much difference if any. It might be some difference on topend but I don't run up there much. The difference might come in when you smash the skinny pedal and the boost goes way up but on my 92 with the slushbox trans I can't tell if I gained anything. As mine stands now the fuel pin could go down another .080/.090 before getting in a bind.
Old Sep 13, 2009 | 10:43 AM
BurrisWill's Avatar
I've got dennys fuel pin and he told me his is designed to run without the washer.
ARbowhunter7
May 29, 2018 11:45 AM
1985cucv
Jul 21, 2008 01:20 PM
Dean Snow
Oct 22, 2007 10:41 PM
Nicholas
May 2, 2007 05:20 AM
BigWaylon
Apr 24, 2006 10:40 PM
