VE pump Return
Old May 2, 2008 | 02:01 PM
xyz12383318's Avatar
VE pump Return
I am running a 1st gen motor in my Suburban. I have a vegetable oil conversion on the vehicle, and my purge times are out of sight. I use three three way valves and used to get a full purge in 45 seconds at idle. Now I am purging more than 1 minute and running for several minutes longer and still getting smokey cold starts. I don't believe my return either from the injectors or the pump or both is funcioning correctly. How much fuel per minute should I be returning and is thre a place I might be plugged or restricted. This is driving me nuts. BTW, I am running a p-pump lift pump so pressure should be high.
Old May 2, 2008 | 03:59 PM
There's a filter screen and an orifice in the "banjo bolt" that connects the return to the VE. That's probably plugged up with some veggie goo.
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
wcbcruzer
Mar 23, 2007 06:29 PM
SPINPOSI
Mar 20, 2007 07:03 PM
