question about oil pressure
Old Aug 11, 2009 | 10:15 AM
Rick 12v CTD's Avatar
my oil gauge has always read on the low side. It seems to be not reading my oil pressure well. The gauge at idle sometimes reads that I have absolutely no oil pressure at all. Basically what I want to know is 2 things. at idle what should my oil pressure be at? and at WOT what should it be at roughly?
I just wanna rule out the oil pump real quickly here. I don't want to replace my engine because I assumed it was the sender or sensor or whatever.
That said, if it turns out the oil pump is fine, what are the part numbers for that oil pressure sensor or sender thingy? that is known to not work right
I wanna get this dealt with asap of course!
Thanks in advance.
Old Aug 11, 2009 | 10:52 AM
apwatson50's Avatar
The only way to know for sure is a mechanical gauge. There is an extra port on the oil filter housing.
Old Aug 11, 2009 | 11:09 AM
yeah I know about that but thanks for saying
Now for the actual pressures... maybe they'll be in my FSM...
Old Aug 11, 2009 | 11:31 AM
justin mcfall's Avatar
Check the connections. Mine was loose and i was getting all kinds of crazy readings on my guage.
Old Aug 11, 2009 | 11:40 AM
ofcmarc's Avatar
IIRC 25psi hot at idle and 50psi hot at ~1500rpm or ther a bouts......
Old Aug 11, 2009 | 05:54 PM
Thunderhog's Avatar
Before Bypass filter 25 idle and 55 cruise hot, now 5 psi less. I expected that though because the Bypass filter is just a "controlled leak"
My wifes Jeep has less than 5 psi at idle, and has forever.
When Landy was alive, we had several conversations about oil pressure. He felt that "some" at idle was sufficent.
Old Aug 11, 2009 | 06:00 PM
Minimum specs per Cummins are 10 psi at idle and 30 psi at rated RPM (2600 for our engines).
Like Thunderhog said - "some."
Old Aug 11, 2009 | 06:18 PM
good to know. I guess it doesn't matter to much so long as oil is getting pumped at idle?
Old Aug 11, 2009 | 08:46 PM
93John's Avatar
I have had a lot of problems with my oil pressure gauge too. I finally got a sender that works, but every once in awhile it will still do funky stuff. I just put a mechanical gauge in.
Old Aug 11, 2009 | 08:52 PM
Rickcher's Avatar
Does anyone know what p.s.i. the marks on the factory gauge correspond to? My oil pressure gauge used to read near the higher mark, then I inadvertantly broke the sender switch and bought a replacement at Advance Auto and the gauge now hovers around the lower mark. "Made In China" maybe?
Old Aug 12, 2009 | 10:14 PM
Riflemanusmc's Avatar
Registered user
From the automotive side is 10PSI per 1000RPM. Sounds like a safe bet for all our coal burners...
leeboy
Mar 26, 2008 11:08 PM
Power Ram 250 C
Feb 20, 2007 11:08 AM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
