Pyrometer install
Old Aug 7, 2009 | 03:41 PM
raggmann's Avatar
Pyrometer install
Ok, I've been searching for the "proper" place to install my pyrometer probe.
I keep running into:
Originally Posted by RollinCoalSmoke
Read the how to sticky on drilling your exhaust for the pyro. There is a divider in the manifold and you need to clear that, one side or the other. Sorry I don't know how to paste the sticky for you here but look it up, there is a world of good info. there. These guys on here have done a fantastic job of compiling info. for us to use. bigbaddiesel you can do all the work yourself by following the stickies. Good luck, and have fun.
I've searched the stickies and haven't found what I need to know. There does not seem to be,or at least I can't find,anything labeled "where to drill your manifold".
Can anyone assit me on this search?
Thanks in advance.
Old Aug 7, 2009 | 03:52 PM
PADuallyBoy's Avatar
Drill into your exhaust manifold, on the left side (Rear three cylinder port) of the neck the flange for your turbo. You want it reading the rear 3 cylinders because they're hotter than the front 3. Hopefully this helps, I don't have any picture, maybe someone might have some somewhere.
Old Aug 7, 2009 | 03:53 PM
cootz's Avatar
Here thee be.
http://www.tstproducts.com/pdffiles/instpy25b.pdf
https://www.dieseltruckresource.com/...9&ppuser=44592
Old Aug 7, 2009 | 03:55 PM
Free89W350's Avatar
here is a good picture from Wannadiesel's gallery
Old Aug 7, 2009 | 03:56 PM
jimbo486's Avatar
i would assume the front 3 may run hotter due to the size of the boss around the #1 cylinder. i could very well be wrong though. but that's the typical position of the thermocouple.
Old Aug 7, 2009 | 04:00 PM
raggmann's Avatar
You guys ROCK.
This post hasn't even been up 20 minutes and I'm ready to be drillin'.
Thanks again,
Ragg
Old Aug 7, 2009 | 04:33 PM
unixcowboy's Avatar
PS --
IF you have any letter drills ---
R is exactly the size of an 1/8" NPT tap
Old Aug 7, 2009 | 04:51 PM
#5 and #6 are typically the first to scuff the pistons though. That's the thinking behind monitoring the rear port.
Old Aug 7, 2009 | 05:12 PM
foxtrot's Avatar
does the pyro have to use a solid core wire ? or will stranded work as well ?
I ask because my wire keeps breaking I asume do to the vibrations of the truck.
Old Aug 7, 2009 | 05:22 PM
93John's Avatar
I have solid core wire extension on mine, thats what came with my pyro. But I have seen a lot of regular stranded wire used as well. Do you have your wire zip tied up tight?
Old Aug 7, 2009 | 05:29 PM
jimbo486's Avatar
any thoughts on why #5 and #6 are the first to do so? are most manifolds typically divided for that particular reason? what about pulse manifolds? never noticed if they're divided or not. i'm almost thinking that they would be so that there are no opposing forces of exhaust gases when they reach the center outlet allowing better flow efficiency? hope that makes sense
Old Aug 7, 2009 | 05:36 PM
Poor coolant circulation.
Old Aug 7, 2009 | 05:38 PM
jimbo486's Avatar
gotcha! i saw a write up about something that can be mounted to the back of the head in place of the freeze plug to help circulate the coolant better. i can only assume it was one of the gurus on here.
Old Aug 7, 2009 | 06:38 PM
foxtrot's Avatar
The last time it broke was on the back of the gauge.
I called ISSPRO they said use the wire that came with it, I will fix it one more time then try stranded.
Its only broke a couple times but I dont think it should ever break.
TinJim
26
Sep 19, 2005 11:58 PM
IH8MYCAT
Mar 13, 2005 04:24 PM
fordsmasher
Jul 1, 2004 07:01 PM
deere nut
28
Jan 12, 2004 12:22 AM
Push Rod
Oct 22, 2002 10:04 PM
