Pump help
Old Sep 8, 2009 | 07:47 PM
boostedve's Avatar
Pump help
tonight i went to turn my pump up and the fuel screw bottomed out so i took it out and welded some on the end.. put it back in and fired it back up. as i went in on the fuel screw and bliped the throttle to get it close to run away i noticed that if i just gave it about 1/4 throttle it sounded like it had a miss so i went a lil further and it would go away so i went a lil more on the fuel screw and got it to runaway and the "i guess miss" went away.. the miss sounds like its got a ton of timing in it.
all said and done its at runaway but when i went to shut the truck off with the manual shut off it would not shut the truck off but it did shut off with key..
this is on my 93 short bed
Old Sep 8, 2009 | 08:17 PM
dzl_damon's Avatar
little peice of slag didn't break off in there did it??!!
Old Sep 8, 2009 | 08:19 PM
boostedve's Avatar
dont think so i took and grinding it down and it looked nice but you never know..
Old Sep 8, 2009 | 09:18 PM
1985cucv's Avatar
mine did this same thing. turn it back a half of a turn and go from there dont want it to be too close just incase you know just make sure you have a buddy with you or you are prepared for runaway. take the intake off the turbo and get ready with a piece of thick flat rubber that is how i shut mine off
Old Sep 9, 2009 | 05:37 PM
boostedve's Avatar
i turned it back from runaway but i still cant shut the truck off with the manual shut off i have to use the key why is that...
Old Sep 9, 2009 | 05:54 PM
Sounds like something broketed inside ...usually its the other way around.
Old Sep 9, 2009 | 06:03 PM
boostedve's Avatar
ill see when i put the 4200spring in it
Old Sep 9, 2009 | 07:36 PM
Sounds like the shutoff lever needs to be adjusted. There's a little adjustment screw that stops the lever, you need to back it out some so the lever goes a little further.
Old Sep 9, 2009 | 07:45 PM
boostedve's Avatar
i pulled the top of the pump off and didnt see anything wrong so i put it back on and tried that and that worked out..
thanks wanna
Old Sep 10, 2009 | 12:58 PM
apwatson50's Avatar
Or if you've ever taken the lever off the shaft, it could now be indexed wrong.
rtmick
Jan 19, 2007 07:02 AM
wana12v
Sep 5, 2006 05:19 AM
bkay
Nov 6, 2003 10:39 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
