Pull Cable
Old Mar 25, 2007 | 09:10 PM
Oldschooldodge's Avatar
Pull Cable
Anyone got any pics of their pull cable set up? Please include what materials you used. If grinding the plunger doesn't work, I might have to become a member of the club. Thanks.
Old Mar 25, 2007 | 10:08 PM
bullfrog5.9's Avatar
ur talking bout a pull cable shut of right
Old Mar 25, 2007 | 10:18 PM
Ilikebikes's Avatar
I used a bike derailleur cable, a little cable tie off thing from a hardware store and a "peterbilt" keyring as the piece I pull. Real simple.
Old Mar 25, 2007 | 10:48 PM
Yes. A pull cable shut-off set up.
Old Mar 25, 2007 | 11:07 PM
i need a pic to under stand it and see how it works
Old Mar 26, 2007 | 12:15 AM
BearKiller's Avatar
Arrow Engine Stop
You can actually get the real thing for big trucks at NAPA and other good parts stores.
The **** will be RED, octagon-shaped, and say ENGINE STOP in big bold letters.
If there is a big truck mechanic, or boneyard, close by, you can probably get one for the asking.
These are not much higher cost than a choke cable, and come with the correct fittings to hook to the shut-down lever, without having to improvise.
Old Mar 26, 2007 | 05:15 PM
maxx250's Avatar
Yeah I just hooked mine up this past weekend and used a choke cable set-up seems to be working well right now.
Old Mar 26, 2007 | 05:44 PM
charger 69's Avatar
Parts
Good idea,I never thought of that I thought big trucks worked by a key also.
Old Mar 28, 2007 | 04:51 PM
They do now.
Old Mar 28, 2007 | 04:58 PM
andyr354's Avatar
farm implement dealer can probably also hook you up.
Especially if it is an older caseIH tractor with the same engine and injection pump.
Andy
Old Mar 28, 2007 | 05:02 PM
EClancy's Avatar
go to napa and ask for a shut down cable for an 80's r model mack, its just what you want.
and old trucks did also use a key, the key just shut down all the trucks electronics and such, but the engine would keep running till you pulled the cable.
mhuppertz's Avatar
I'm thinking about removing the clock spring on mine and hooking it to a solenoid so I can use my cool down timer again. I really hate having to sit there for 5 minutes in my driveway, then killing it with the clutch.
Old Mar 28, 2007 | 08:36 PM
Boatnik's Avatar
Check my gallery.
90firstgen
Apr 13, 2008 05:48 AM
Kirk T
Sep 20, 2006 07:19 AM
A-Poc
Dec 2, 2005 05:58 PM
Boatnik
Oct 29, 2005 08:29 AM
hellotbone
Oct 7, 2003 06:54 AM
