Preventive Maintence - Getrag
Old Jun 30, 2006 | 04:02 PM
Underpsi's Avatar
What kind of preventive things could I do with my getrag while its out. I don't think I could rebuild it myself nor do I think it needs it but I thought maybe I should check some things out. Any ideas?
Old Jun 30, 2006 | 04:29 PM
flashgordon's Avatar
the screws that are on the shift tower need to be sealed.....if thay are leaking,the shift tower where it bolts up to the case
Any place that you see a leak fix it while it simple to do.
Check the output shaft for exsesive play(posible front bearing problems)....mine was tight or vary little play!
Old Jun 30, 2006 | 05:01 PM
bgilbert's Avatar
Any leaks? I opened the top on mine and made a top cover gasket out of some gasket paper because my top cover was leaking. If no leaks, put it back together!
Old Jun 30, 2006 | 05:06 PM
Underpsi's Avatar
How much if any free play should there be on the input and output shafts?
Old Jun 30, 2006 | 05:10 PM
How should I check free play on the input and output shafts?
I don't have any spec to give you but if the input shaft can be moved a lot say....hm....a 1/4 of and inch,back and forth you might want to take the coller off(what the throw out bearing rides one) and see how the bearing on the input shaft looks.
Old Jun 30, 2006 | 08:07 PM
G1625S's Avatar
The 'rag is setup with bearing preload. I'm looking up the specs right now, but I've got to think even a loose, worn out unit would still have .003-.005 preload, meaning no shaft play...unless there's a shot bearing, of course. Sounds like you've got a decent unit, so I'd say just run it
Old Jun 30, 2006 | 08:20 PM
G1625S's Avatar
The bearing preload spec (in inches) .006--.008
Old Jun 30, 2006 | 09:52 PM
Underpsi's Avatar
what about up and down free play on the input shaft?
Old Jun 30, 2006 | 10:04 PM
There should be no play whatsoever on either shaft. The trans is built with preload. If you can move the input shaft around the input bearing is toast.
Old Jul 5, 2006 | 05:29 PM
Underpsi's Avatar
The input bear has some up and down play so I've decided that im gonna replace it. I see the 4 bolts that hold it on but does the top cover need to come off to get it out?
Old Jul 5, 2006 | 05:41 PM
Yeah, you pretty much have to tear the whole thing down to get at it.
Old Jul 5, 2006 | 06:03 PM
there i go again, trying to us nv4500 theary to a getrag......You guys have kinda skeerred me tho cus there was some play.....not bad but some play in the input shaft is that why my pilot bearing was so bad
My getrag is pritty much noise free right now but i'm wondering, for how long now?.....so the .007 was press fit not end play?
Old Jul 5, 2006 | 07:59 PM
Underpsi's Avatar
huh that sounds kinda in-convienient. I pulled the cover off and the race will come out but the shaft won't. The race doesn't look too bad it doesn't have any pit marks or anything and doesn't have a groove. The bearing looks like it has some pit marks on the cage but not the actual rollers
SmittysRam
Mar 22, 2015 04:31 PM
Dodge@KY1997
Feb 10, 2007 05:42 PM
bumpytruck
Feb 4, 2007 08:14 PM
eot
Dec 27, 2003 03:43 PM
quantrill88
Jan 8, 2003 10:05 AM
