The pressure's been building and I've got to vent . . ..
Wouldn't it be easier to put a new set of rings on the pistons to control you original problem? I know it would not be as much fun though.
I sure wish the 6BT was designed to take a liner like the big boys do, then we would be talking about doing inframes.
Why not evacuate the vapors using a scavenger pump and inject them into the exhaust downstream of the turbo where the gasses are still hot enough to vaporize them, shouldn’t have much smell then.
For RV’s there used to be a system that took the waste from the septic tank and used the heat of the exhaust to incinerate it or maybe cremate it.
I have been behind some big tour busses that had exhaust that smelled like diesel and a hint of poop.
I am sure if you got too much vacuum in the crankcase that it could rob you of your power.
This is what happens when you're on-call, nobody's calling, and you've got a cool CTD sitting in the backyard. But then again, we're aliens, and that's how we roll.
- Go with some after-market pistons, relieved to accommodate the appropriate cam of course.
- Trick connecting rods with rod studs no doubt.
- Main bearing studs.
- A girdle to tie the main bearing bosses to the block.
- Radius all sharp edges inside and out.
- Perhaps paint the interior with some electric motor winding enamel.
- Dry sump . .. ? But that would mean a trick accessory drive-belt system.
But then all that would mean the long-block could now readily handle a wee-bit more power and RPMs.
Ya see?
My name is David, and I'm a CTD junky.
Keep a close eye on that air filter. I think that with the blowby coming in before the filter you are going to wind up with a oil soaked filter in a pretty short period of time. If I was going to route my breathers to the intake I'd do it after the filter.
Why not use an oil that doesn't stink, like Delvac 1300?
I'm currently running Amsoil in the engine. As expensive as it was, it'll be there a while.
I like the info so far that I read about this... I am just wondering why no one ever uses a universal oil filter spin on adapter with a oil filter. The filter will catch all the oil and you will have no mess. Al you would have to do is replace it every so often and you are good to go.
As long as we're on the blow-by subject, decidedly low-tech, but if you are just unhappy about a post-park drip on the floor you can do something like this:
http://stuff.is-a-geek.net/PhotoAlbu...cs/CTD_112.jpg
That's a Coors Gold can, BTW - arguably one of the worst beers on the planet.
http://www.maesco.com/products/racor...ccv_intro.html
I THINK THIS IS WHAT YOUR LOOKING FOR
Now I have to figure out what cfm we are talking about?
