power window issues
Old May 10, 2015 | 03:30 PM
1991.5 mopar's Avatar
power window issues
since i bought the truck i could move the passenger and driver window up and down by hand. if you push the up or down control you can hear the motor working but doesn nothing. the previous owner said both windows fell down after hitting a big bump in the road. i pulled the door panel today and couldnt come up with anything. i think ive narrowed it down to the regulator or the motor. whats your guys two cents?
Old May 10, 2015 | 04:53 PM
jimbo486's Avatar
Rebuild your motors. Look in The Sticky for a full write-up on just this kind of issue. The small planetary bushings have disintegrated and aren't actuating the gear that acts on the regulator to move the windows up and down.
Old May 10, 2015 | 05:54 PM
Okay I'll take it apart and see how bad the gear is. You know of anywhere to find a replacement gear?
Old May 10, 2015 | 07:52 PM
MARF75's Avatar
Dorman part# 747-411
Bought 2 in the last month from Carquest, they had to order them.
Old May 11, 2015 | 12:09 AM
I pulled the window motor and pulled the cover and gave it power and the drive gear from the motor was not engaging the large plastic gear. I'm guessing over time the plastic gear wears out and no longer engages. I ordered 2 new gears, hope it fixes it. I was messing with the driver window and knocked the roller nearest the handle off the hinge and couldn't get it back on. You know an easy way to get it back on the tract?
Old May 11, 2015 | 09:24 AM
Here's what the gear looks like
Old May 11, 2015 | 08:23 PM
i pulled the regulator to lube it up and the spring fell out and im not sure which way it goes and ive tried it a couple different ways and cant get it right, anybody have a picture how it goes?
Old May 12, 2015 | 04:05 PM
Pretty sure the write up in the sticky has pics and a full walk through on how to repair these.
Old Jan 27, 2017 | 07:50 AM
LBourque's Avatar
Sticky
Must be showing my age but how do you access a sticky? Now that the VE pump is done I'm fixing drivers door power window,spring fell out.
Thanks
Old Jan 27, 2017 | 08:02 AM
patdaly's Avatar
On this forum, 3rd from the top, it is a thread aggregation of informative threads.
https://www.dieseltruckresource.com/...sticky-102027/
Old Jan 27, 2017 | 11:06 AM
LBourque's Avatar
Balance spring orientation
Been searching for coupla hours and can't find the write up on the regulator spring. Any help would help!
Old Jan 27, 2017 | 11:07 AM
LBourque's Avatar
Same here
Did you get an answer about the spring? Mine popped out too and I'm scratching my head!
Rednecktastic
Aug 29, 2010 11:26 PM
raven392003
Oct 29, 2007 11:39 AM
jgiachino
Jul 13, 2007 09:19 AM
TxDiesel007
Oct 13, 2005 08:37 AM
TxDiesel007
Aug 10, 2005 06:03 AM
