Power Steering Pump Seal...
Old Jun 17, 2010 | 08:53 AM
Paul S.'s Avatar
I am wondering if there is a place to buy the seal between the power steering pump and the vacuum pump? I just replaced my ps pump because it was leaking so bad but it now leaks even more.... Any thoughts or words of advise?
Old Jun 17, 2010 | 09:26 AM
james1's Avatar
Question which fluid?
Are you leaking PS fluid or engine oil through the vacuum pump?
Old Jun 17, 2010 | 09:41 AM
Paul S.'s Avatar
The ps fluid seems to be coming from the seal between the ps pump and vac. pump. Does this suggest the ps pump is bad? It leaked the day i put it in.... bought it at Napa so I thought I would be ok...
Old Jun 17, 2010 | 12:37 PM
GasganoFJ60's Avatar
Are you sure you are leaking PS fluid? Check to be sure.
If the leak is where you say it is, you're probably leaking engine oil.
I rebuilt my vac pump to take care of all the leaks. I cant think of the company that I bought the kit from off the top of my head but it was about $60 for a kit which came with two sets of seals and a video of how to rebuild it.
I recommend replacing the PS pump while you're at it. I didn't and wish I had, the pump has gotten weaker. Shoulda done it when it was all out.
Old Jun 17, 2010 | 12:45 PM
maybe368's Avatar
here is a kit http://www.fixinrams.com/id21.html and another http://www.genosgarage.com/prodinfo....OULD_VPRK_9195 Mark
Old Jun 17, 2010 | 02:13 PM
Paul S.'s Avatar
Thanks. It is ps fluid for sure. I literally just had everything apart 2 weeks ago and replaced the ps pump... My first thought was oil but collected the leak one day to make certain. I would assume if the ps pump is leaking out the shaft it must be bad as like I said before it has done this since the day I installed it....
Old Jun 17, 2010 | 04:18 PM
Onemoparnut's Avatar
I would be taking that pump back to NAPA if I were you.
Old Jun 17, 2010 | 04:24 PM
Paul S.'s Avatar
Unfortunately I think that is my next step....
tony99
Apr 9, 2014 08:25 AM
freight train
Oct 5, 2010 05:20 PM
92smokin blacky
Mar 30, 2010 06:09 PM
1985cucv
Nov 27, 2008 09:30 AM
DodgeCowboy
Aug 28, 2006 08:57 PM
