Power steering pump full of foam
Cold this morning when I went to start the truck. Got it fired and heard the power steering pump moan like it need fluid. Pulled it into shop and noticed it had a leak. Pop the hood and it looks like it had spit fluid out the top. Any thoughts Thanks n advance
As a rule, if the unit wasn't low and it got the foam, you have air getting in on the return side, look for a split, crack, rub, etc.
It will do the same thing though if the unit had a slow leak and it got too far down on the fluid level.
I take it that this is a common problem then. I've had several 24 valve cummins. This is my first 12. I'll check for leaks tomar. Thanks for all the advice
Dave88LX
61
Nov 23, 2014 02:17 AM
j
Nov 14, 2003 09:38 PM
