Is it possible to just buy injector nozzles for 92 ?
Old Mar 9, 2009 | 07:55 AM
SeanB23's Avatar
So I'm gradually working through my new old truck...
Replaced oil, oil filter, fuel filter, air filter. Ran a few tanks of B20 spiked with a little fuel injector cleaner before I changed the fuel filter, too.
Adjusted valve lash...good and tight, .10 and .20 feelers fit, but you have to really push them in.
But it still kind of has a slight "chug chug" sound to it at idle if that makes any sense. Maybe that barely noticeable lugging sound at idle is normal for the Cummins 5.9 for all I know, these are new to me. Runs fine enough, but when I compare it to a friend's 91 non-intercooled 6BT, it just doesn't idle as smooth or strong, nor does it put out as much power. Drove both, same tranny.
So I figured what the hell, the thing has about 250,000 miles on it, maybe the injectors are starting to get a little tired.
Is it possible to just buy the nozzles for these and replace them, as opposed to shelling out $400 or more for a set of 6 injectors ?
Back when I ran a 6.2 GM/Detroit...slow turd, I know...I replaced it's injector nozzles. Got 'em from RockAuto. It wasn't that difficult at all. Ran great, but it had to go. I wanted a Cummins.
So why when I look on the internet here, are only whole injectors offered for the 5.9 Cummins ?
If I'm stuck buying whole injectors, what's the best bang-for-the-buck ? Keep in mind, this economy is killing me, like many other folks.
TIA.
Old Mar 9, 2009 | 12:20 PM
MBolivar's Avatar
Sean,
I don't know what the prices are in Oregon but, it's around $50 to $60 here for each injector to clean and pop test, if that's what you're looking at. For about a $100 or so more, you could have yourself and new set of Bosch 190's and step things up a notch. Just a thought.
Aloha~
Old Mar 9, 2009 | 01:25 PM
roxxx's Avatar
lol i tried to buy nozzles from DDP the stage 4 they wanted 649 bucks for the nozzles granted there is some work done to them but i thought that to be a bit steep
Old Mar 9, 2009 | 01:45 PM
crewcabxlt's Avatar
Ive tried unsuccessfully, if you know the right guy at the right shop you might could,you still should reset pop pressure though. good luck
Old Mar 9, 2009 | 08:38 PM
nope, thats not really that steep.
their clean running efficient good power making injectors. Very nice upgrade.
If your looking for dirty smokey good cheap power then POD's are ok, but i would'nt recommend them
Personally I think the injectors archer39 has are the best for the money. 435's they're called from coal train diesel performance $500ish and they're 5x14.... ddp4's are 5x13's...... They may not run as clean as DDP4's but they will make a little more power.
5x.014 435 injectors > DDP4's .......they're both considered around a "80hp injector"
Old Mar 9, 2009 | 08:45 PM
Your friend's 91 non i/c feels like its making more power because it kinda is .LOL
They have way faster spooling exhaust turbo housing then your 92 has so the power comes in quicker with minimal lag, and non i/c trucks had more factory timing and pretty big injectors in them stock,
What your 92 does'nt have going for it is the "lagmaster" exhaust housing, ditch that and get say a 12cm (no towing hot egt's, super spooling) or a 16cm (towing and good egt's. good spool) exhaust housing is your choice. that alone will click up the seat-o-pants HP meter.
Old Mar 9, 2009 | 09:01 PM
roxxx's Avatar
For nozzles ??
That price is for the Nozzles only 600 and change DDP charges 700 and change for the stage 4 injectors I have new body's already plus i have a shop that will do the pop test and re phase my pump he just cant do the nozzles also I am north of the border so tack the exchange rate and duty and shipping then it become Crazy
Old Mar 9, 2009 | 10:19 PM
SeanB23's Avatar
So changing out the exhaust housing alone makes a big difference...where is a good place to pick up one of these exhaust housings on the cheap ? Used is fine by me. Which do you prefer ?
Old Mar 10, 2009 | 02:03 AM
SeanB23's Avatar
OK, so I'm looking around at what's for sale. PDR has the 16cm housing for $165, that's about the cheapest I've seen. Maybe one of you guys has one laying around unused you want to sell ?
This is a simple bolt-in mod for a 1992 ? I take it what I have on there is non-wastegated ?
Old Mar 10, 2009 | 03:37 AM
MBolivar's Avatar
From the Coaltrain Diesel site:
For your Cummins we offer the following:
1st Generation
* 5x.012 for $375. These give approximately 80-100 additional HP.
* 5x.014 for $500. These give approximately 140 additional HP.
He's gonna need some air!
Old Mar 11, 2009 | 10:58 AM
brainfade's Avatar
SeanB23,
I have an intercooled 5 speed truck with the 16 housing and I'm pretty happy with it. It spools pretty good and tows heavy without EGT issues even with the PODs. It's a huge improvment over the lagmaster 21. What you could do that will help for cheap is look for an 18.5 housing. Lots of guys have those laying around and while not as quick as a 16 it's still worlds better. Personally, if you are going to tow or have plans for ANY injector up grade, skip the 12 because you'll just be changing it later. My $.02.
As for the grumpy idle, take a look in the sticky about advacing the timing. It's easy and free and will get you a little more snappy sound and help on the top end.
Old Mar 11, 2009 | 02:06 PM
STACKED's Avatar
1st Generation
why cant i find coaltrains web site
Old Mar 11, 2009 | 04:08 PM
http://www.coaltraindiesel.net/main.html?src=%2F#4,1
Old Mar 11, 2009 | 04:29 PM
archer39's Avatar
I have their (coaltrain) injectors and had no problems with them in the 4-5 months that they were installed. Good economical injector.
dodge_24
Aug 30, 2009 08:50 PM
mtomac
32
Dec 20, 2004 02:08 PM
jlells01
Oct 22, 2004 06:29 PM
Zino
Aug 2, 2004 06:10 AM
Amish hauler
Feb 22, 2004 09:42 PM
