extrude honed vs edm injector nozzles
Old Dec 11, 2004 | 12:44 PM
mtomac's Avatar
I know a little about both but what makes EDM injector nozzles better or worse than extrude honed injector nozzles for bosch common rail w/ cp3 pump, mainly the 03 and up cummins and Duramax
Old Dec 11, 2004 | 01:08 PM
Got Juice?'s Avatar
EDM's usually start life as a 'blank ' tip with no holes in them.
Extrude honed are usually existing holes made larger
Benefits of EDM is more precise holes, and correct spray angles can be maintained
Old Dec 11, 2004 | 01:12 PM
mtomac's Avatar
how about using the edm process to enlarge the stock holes or make more of them?
Old Dec 11, 2004 | 01:51 PM
Got Juice?'s Avatar
That is something you would need to talk to Don M about MT
Send him a PM via NWBombers. He is on there a fair bit.
Old Dec 11, 2004 | 08:25 PM
Gypsyman's Avatar
Is this Got Juice from the NW Bombers?
Richard
Old Dec 11, 2004 | 10:55 PM
Got Juice?'s Avatar
Richard
The same
Does that make me famous?.... or infamous?
Old Dec 12, 2004 | 01:33 PM
Gypsyman's Avatar
I'd say BOTH! Good to see ya' around. Was the video on the NW Bombers of the duallie from the back, launching from a stop, yours? If so you should post it here.
Richard
Old Dec 12, 2004 | 01:38 PM
Got Juice?'s Avatar
Not mine Richard, IIRC that was Lance (TLRMAN)
Good laugh that one... the imports were sure impressed!
Are you gonna make it up to PDR or BD this year?
I know the guys at DDP want to dyno my DMX, but I can't convince myself to drive another 4 hours off the beaten path to do it.
Sucks to live in the middle of nowhere sometimes
Old Dec 12, 2004 | 03:12 PM
Gypsyman's Avatar
While I'm off this winter and I'm going to go over to DDP for a set of ARP studs and some dyno runs.
Back to your regularly scheduled programing...
Richard
Old Dec 12, 2004 | 07:59 PM
joeservo's Avatar
Most EDMs can't get smaller than 10 or 12 thous. A have some friends (you them tomac) that had 4 of the 8 holes enlarged to 12. personally think they lost power over extrude honed injectors.
EDM is a better process. Extruding makes the tip look like an injector with 100k miles on it but they are cheaper, should be but dealers mark up quite a bit so the savings may be very close to customers.
if this is for a common rail application, my choice is extrude honed. wide open performance offers them, i;m sure others do as well.
Old Dec 15, 2004 | 05:55 PM
Don M's Avatar
DTR Advertiser
Either way works well if done correctly. I extrude hone the stock nozzles or provide brand new custom nozzles. I have not done much with the DMAX yet. Some prototyping ,etc.
Depending on what the application is...I can pretty much come up with a solution on fuel delivery.
I can make a hole as small as .001 with a laser or about .0035-.004 with EDM. .004 all day back to back in any depth to .100
Don~
Old Dec 15, 2004 | 06:02 PM
Got Juice?'s Avatar
Don, In regards to EDM VS extrude hone, Isn't EDM a better System as it allows you to respect the factory spray angle?
IIRC wouldn't extrude honing an injector tip be prone to a less efficient spray pattern because of this?
Old Dec 15, 2004 | 06:44 PM
Don M's Avatar
DTR Advertiser
No, extrude honing does not really change anything on the spray pattern. The impact remains roughly the same. The drawback to EH is the internal seat destruction.... if it is not done properly. Erosion of the metal you need in the seat is washed away with aggressive/improper honing.
Recall the nozzles are lightly honed from Bosch to reduce the flow tolerance between them all. I stress lightly.
Not all EH'ing is created equal. We have some 125 HP EH nozzles that never pop or bang. Most others cant break the 80 HP mark without the poping at high rpm. At last check, I have a guy with just over 90,000 miles on some honed 90 HP injectors. It can be safe, if its done properly.
EDM just gives a total flexibility to make whatever you like. Hole size, number of, angle of the cone, etc. This can eliminate honing altogether and get the flow rate you want.
Don~
Old Dec 16, 2004 | 11:38 AM
mtomac's Avatar
Yea, I can get a set done locally for little $ but he can't make anything below .10 and I don't want to just make a couple holes that big and leave the rest alone.
I still have stock nozzles.
Old Dec 17, 2004 | 08:00 PM
nebuniRAM's Avatar
Kax motor sports at Timberline dodge in portland oregon sells EH ijectors for the 600, claims 80+ hp at RW and +150 tq, also dont know much about this process/injectors, they say it will not void my warranty. I am seriousely looking into it, at $1200 installed doesnt seem that bad for non warranty voiding power, what do u guys think?
