Piston Pump Regulator Spring?
Old Oct 17, 2013 | 01:17 PM
sinthome's Avatar
Hi folks, this is my first post! I have a 93 W250 with the stock lift pump. I want to go to the more reliable and higher flow piston pump and have probably read everything about the upgrade that I can find on the net.. twice. I now know that I don't want to use a pressure regulator on the 2nd gen pump and I don't want the super cheapo low low pressure version that seems to be the only version of part 3936320/4988751 that I can find. That leaves me with the option of getting a high pressure 2nd gen pump and then changing out the spring. The only leads on this option I have been abe to find, so far, is the pre-modified pump at Hungry Diesel for $185 or their regulator spring for $50 plus a cheaper pump. Fifty bones seems a bit steep for just a spring so I started looking for another source. I found: http://www.jegs.com/i/BD-Diesel/151/...d=#moreDetails But I have no idea if this will fit. Can anyone help? Thanks!
Old Oct 17, 2013 | 02:02 PM
dB Zac's Avatar
There is a low pressure high volume mechanical lift pump. It takes a spacer and a new fuel line to run it, along with a minor mod to the push rod cover. I run this set up and it works great
Sent from my HTC One using Tapatalk
sinthome's Avatar
Ok I found some useful info in this thread-- http://www.cumminsforum.com/forum/94...ing-mod-2.html the posts by kyle41005 sort of specify the spring size. Any thoughts on what the stock spring rate is or how this translates to output psi? I am looking for 12 psi and no more than 15 psi. My truck is close to stock.
Old Oct 17, 2013 | 02:39 PM
cougar's Avatar
Nothing wrong with the Delphi pump. It supported my 7X.010s and big turbo to 3200RPM with no fall off.
Old Oct 17, 2013 | 03:10 PM
I bought my complete kit from OFI (oregon fuel injection) About 3 years ago. Delphi pump, spacer, and gaskets....about $80. Have not had any problems.
Old Oct 17, 2013 | 06:57 PM
dB Zac's Avatar
Ya, I think that's where I got mine to
PeytonMaterne
Aug 11, 2008 10:00 AM
Elohim1
Apr 12, 2008 03:38 PM
Txwelder
Feb 27, 2008 01:03 PM
dieselJon
Aug 29, 2007 10:41 AM
CTD99
13
Aug 23, 2005 10:55 PM
