Regulator for Piston LP
Old Aug 28, 2007 | 04:02 PM
dieselJon's Avatar
Who or what do I need to make/get a regulator for a piston LP? I found one but it is for a 2nd Gen. A couple of guys here (Greg and BC847) said it was a good deal but I needed a regulator. So is there a way to fab up my own?
I need a new LP as I pushed the top of mine in slightly when I was trying to take off the fitting for the fuel-in port. Ugh. So with me wanting to have enough fuel for future mods, I thought, why not put one in now.
Thanks!
Jon
Old Aug 28, 2007 | 04:47 PM
MikeThomas's Avatar
Hmm, the piston pump I have doesn't need a regulator, but I am sure if you use a stock 2nd gen LP you will have to regulate it somehow.
Old Aug 28, 2007 | 05:22 PM
BC847's Avatar
1st Generation Admin
What he's talking about is the low pressure spring that makes a piston LP work with our trucks. There's the high pressure spring that makes it work with the 2nd Gens trucks as well. Otherwise, the pumps are the same if I'm not mistaken.
I can't find the part numbers for either.
Old Aug 28, 2007 | 05:33 PM
hertz's Avatar
look in www.summitracing.com or www.jegs.com you might find a regulator you need
Old Aug 28, 2007 | 06:07 PM
banzaitoyota's Avatar
look up my posts, I installed one and it works fine
Old Aug 28, 2007 | 06:21 PM
bobva's Avatar
Just For The Heck I'd Calls Cummins And Get The 3936320 Rebuild Kit
Couldn't Be More Than 4o Bucks
I Just Got Hole Pump 8o Bucks Plus Change
Old Aug 29, 2007 | 08:26 AM
Short Box's Avatar
Just so I understand, do I need to put on a regulator when I install my lp 3936320???
Old Aug 29, 2007 | 08:54 AM
Boatnik's Avatar
That pump only puts out 15 psi. It is an industrial engine pump. Not a Second Gen. pump. No regulator is required. all you need are the parts listed in the "sticky" under misc. Cummins part numbers. Piston LP.
Old Aug 29, 2007 | 10:41 AM
Short Box's Avatar
thanks,I just ordered one so I wanted to make sure
sinthome
Oct 17, 2013 06:57 PM
Elohim1
Apr 12, 2008 03:38 PM
CTD99
13
Aug 23, 2005 10:55 PM
hellotbone
Oct 9, 2002 02:20 PM
