accumulator piston spring
Old Feb 26, 2008 | 08:41 AM
Txwelder's Avatar
What would the tranny gods say if you happened to accidentaly leave the spring out when putting the accumulator piston back in the tranny? Ill effects? Damage? Improper operation? Thanks.
Old Feb 26, 2008 | 03:16 PM
dozer12216's Avatar
Oh my goodness: the sky is falling. The tranny gonna kiss its gonads.
No it won't.
This used to be a old performance trick.It will now cause some harsh shifting. My favorite for this item is reduce travel slightly. I find a couple washers of right size and place on top of accum, so it reduces total travel, but still moves. Leave the spring in. Hold the accumulator in during vb install by using feeler gauge stuck into spring and pan bolt holding feeler gause in place till get screws in VB.
Old Feb 27, 2008 | 06:19 AM
Txwelder's Avatar
Well it definately shifts hard. I will probably put that spring back in when I do the next fluid change. Do I have to yank the VB completely or can I just unbolt and swing it out of the way some?
Old Feb 27, 2008 | 01:03 PM
dozer12216's Avatar
You will be lucky if can swing down enough to push spring in. Then you take chance of damaging shift shaft seal and wiring connector.
jta
0
May 5, 2007 09:24 PM
CTD99
13
Aug 23, 2005 10:55 PM
TGCTD
Jul 27, 2005 01:36 PM
guzzirider
0
Feb 16, 2005 06:31 PM
gofastman
Aug 10, 2003 03:02 PM
