Piston LP and updated gallery
Well I got some of the parts a couple months ago for doing the piston lift pump conversion and I finally got it all together this weekend. I haven't been able to take her out for a good spin yet as its snowing. I didn't want to spend the $500 cdn$ that it would have cost to do the cummins conversion. So i decided I would do it my own way. I wanted a less restrictive system and wanted the higher psi pump. I had to drill and tap out the filter housing because the threads on the banjo bolts are an odd thread and it would have cost too much to have an adapter made so I tapped both the inlet and outlet to 1/4npt. I also wanted bigger lines too so i put reducers on everything to 1/2"npt. The only thing i purchased from cummins was the spacer plate and a gasket. I bought the piston lp from a local bosch dealer for $80cdn!!! I was pretty happy about that, its an industrial ve pump style piston lp so it is lower psi then those for the p-pump. All together I spent about $120cdn on it and got a better gain from lowering the restriction.
I also finally loaded all my pics off my camera so theres quite a few more pics in my gallery now, including pics with the 20"s on so have a look if you like. If anybody has any questions about my conversion i'd be more then happy to answer them
Patron Saint of 1st gens
Hey, sounds like you got it all done on a decent budget....let us know how you make out with this.
Do you have the Cummins pump part number you could post...I'd like to look at that option myself..
pb....
pb....
Ya I was very happy with the money spent on it. I have the cummins part number but I did not use the pump from cummins i got it from my local bosch dealer. I'll be sure to post any results when i get the chance to take it out
Originally Posted by Underpsi
I do not want to post part number right now as i haven't really tried it out yet and have seen seen the range of psi with this pump
Originally Posted by bgilbert
I'm impressed. I didn't think I'd like 20's. Looks pretty good with the stripes you have down the side. That engine needs some paint though..
I don't see any fuel supply problems in your future! That is some nice work.
Originally Posted by monty
Nice work indeed! Did you run the new supply line all the way from the tank? If so, how did you tie into the tank?
BIGDAN65
12-17-2007 07:43 AM
jrs_dodge_diesel
08-26-2006 08:01 AM
