Pickup Bed Weight
Does anyone know how much the pickup bed (unloaded) and tailgate weigh? Meaning, if I was to remove them, how much lighter does my truck get?
Also, how much physical space does a gallon of diesel fuel consume, in cubic inches? Lets say I want to build a fuel tank that will hold 100 gallons (which I do) how many cubic inches do I need to make it's capacity?
Finally, if there is water in the fuel in a fuel tank and the bottom of the tank comes to a point (think of a pyramid turned upside down) and at the very tip of that point there is a drain ****, opening the **** until fuel comes out instead of water should be effective in permitting removal of water from the fuel tank, provided that the vehicle has not been recently moved, i.e. the water (which I presume emulsifies itself with the fuel due to vibration when traveling down the road) has had a chance to separate and settle, i.e. being parked overnight, correct?
I like the tank idea too, but I am not looking forward to building it. What I am going to have to do is get four pieces of aluminum diamond plate from the metal place and have them sheer it into four triangle shapes, then each of them is going to have to be welded inside and out. Dad has the welder and can weld aluminum, but this tank is gonna have an awful lot of welds and they all have to be good otherwise its gonna leak.
Hmm, so then about 350# it sounds like.
Kieth, The tank drain is a good theory but you have to ask yourself ARE YOU REALLY GONNA CRAWL UNDER THERE AND DRAIN IT!!!! There are commercial filtration /heater systems that tap inline of your fuel system that perform the same function. You can check a commercial salvage yard for used one or purchase new at a commercial dealer (Pete,Kenworth,etc.) heck Napa might even have a system. I don't deal to much with them but i know they sell commercial parts. Check around you will find something. I like the 100 gal. tank idea
Merry Christmas!
Don't forget he was born to save us from our sins!!
Merry Christmas!
Merry Christmas!
Merry Christmas!
Will I be under there draining weekly? No, no I will not. But I will be under there occasionally purging the water from the tanks. Plus, it will give me the option of draining the tank without removing it and even that will be a great improvement over what the factory tank offers.
Don't forget to incorporate baffels into that tank. 20 gallons sloshing in a 100 gallon tank ain't good.
I'm sure you can plumb in a drain that is convenient to access, like the frame rail. Kind of like the air tanks on semis. I'd rather drain a tank ocassionally than have a little more new crud deposited every time you fill up.
sdaly
Apr 28, 2005 07:19 AM
MrBilly
May 8, 2003 02:02 PM
