Permanent Fix for Shutdown Solenoid
Old Nov 19, 2007 | 07:32 AM
Ace's Avatar
Ace
So I do the pull cable thing a few months ago and figure great, don't have to worry abut that thing anymore, right? Not. Noticed it leaking the other day. More like seeping, just wet around there. Awright, guess I didn't get it back in there tight enough. Ya know, it is kinda hard to get a good grip on that thing with that useless bracket in they way...
So I cut the bracket enough to enable proper wrenching, etc, etc. and the dang thing is STILL leaking. Upon closer inspection, I come to see it is actually leaking through the top of the plug assembly itself. Evidently the hard rubber plug the solenoid asembly is made from has decided to become compromised in some way, allowing it to leak. I'm guessing heat-cold cycles, since it got pretty cold here a few nights last week. Has anyone else seen this?
Well, the fix is dead simple. Of course you could go out and spend $40 for a new one you don't really need or want. Or: Put the thing upside down in a vise, knock the solenoid out with a punch and BFH, tap the plug core for 1/2x14 with a bottom tap (can be made with a regular tap and grinder) and install a 1/2" pipe plug using JB weld for thread lubricant. Screw back into pump the following morning. This is one of those applications that is just perfect for JB weld.
Old Nov 19, 2007 | 11:37 AM
90firstgen's Avatar
Good work Ace!
Old Nov 21, 2007 | 01:39 PM
bigbrad's Avatar
what was happing was your truck shuting down when you get on it i am having the problem i dont know what is wrong
Old Nov 21, 2007 | 01:44 PM
Ace's Avatar
Ace
No, just leaking a little. Check the connection on that solenoid. Bad plug/wire is one of the usual suspects when they do that. That's one reason I decided to eliminate the thing altogether. It's an unreliable convenience feature allowing it to be shut down with the key like a gasser.
Old Nov 21, 2007 | 09:45 PM
rlyons's Avatar
Just one word of advice if you have a standard transmission, make sure when you pull the cable to shut down that you leave the cable pulled out while you are parked. One of my wrecker drivers bumped the bumper of a semi which was shut down with a cable and the truck started and drove off without a driver with it's doors locked. Could be a parking lot disaster if you know what I mean.
Old Nov 22, 2007 | 07:13 AM
Ace's Avatar
Ace
I removed the return spring from the shutdown lever so when I pull the cable it stays pulled until I push it back in.
Old Nov 22, 2007 | 08:15 AM
BearKiller's Avatar
Good advice.
Our old 990 David Brown has a TEE-handle on the kill-cable.
When it gets pulled back to KILL, it engages some sort of lock; to release it, the TEE has to be turned contrary-clock-wise about 1/8 turn.
ndtguy1
Nov 27, 2003 09:48 AM
mechanic
24
Sep 26, 2003 11:46 PM
Fishinghaoliboy
Jun 28, 2003 08:33 PM
Numero Uno
Mar 23, 2003 08:14 PM
taz1456
Oct 27, 2002 09:01 AM
