overdrive question
overdrive question
is it possible to get my overdrive to work without having my speedo working?
i hate the drone at 45 and want it to kick up to the last gear, but i have no speedo cable whatso ever coming from my tranfercase, i think it got ripped off by the previous owner.
There are 2 wires that go to the trans to the od selonoid. One has power when the key is on the other just needs to be run through a switch and then to ground. Then whenever you flip the switch od will engage.
can someone just tell me what side on the od plug on the tranny is hot and ground. if you have the nub face you is it on the right or left prong?
or better yet a pic that shows what side of the plug the blue and what other color wire?
I was asking about the pins on the trans side. I don't have a plug on the wiring harness side of things so I don't know how the plug is laid out. Unless hooking it up backwards wont blow it up inside the trans.
72demon440
Apr 27, 2007 10:45 PM
Mr.Blonde
Sep 21, 2004 09:31 AM
Mike S.
Jan 24, 2004 05:19 PM
