Oil for winter?
Oil for winter?
Simple ?, does any one on here drop to 5w40 for the winter for those cold mornings. And if so how cold before the change over.
In my MB diesel I couldn't get it to crank over fast enough to catch even with a brand new battery when it dropped below 0 or -10*F. Switched from Rotella 15W40 to Synthetic Rotella 5W40 and she turned over MUCH faster, and started much easier for me! I was sold.
Now I'm out of school, I exclusively run Synthetic 5W40 in all my older diesels.
I usually switch to 5W30 for the cold winter months,
I mostly do short distance driving and the engine hardly ever gets up to
operating temp. Makes life alot easier for the engine under these conditions.
I put rotella 15/40 back in in the spring.
With my '92 I never used anything other than 15w40. However, I did notice after a while that Rotella 15w40 had the consistency of tar in cold temps, where Chevron Delo 400 of the same weight would still pour fairly well. Because of that I switched to Delo 400 15w40 and used it year-round.
My '92 would start in -20 deg. F. temps routinely if I forgot to plug in, although it sounded like crap and it's very hard on the engine. Best thing you can do even if you run full synthetic is to put a pad heater on the oil pan and use it.
Mike
Mike
Winter Oil
I use Delo 15 - 40 year round, but I have two pan heaters, a battery maintainer plus the block heater. I've started mine at -46F after plugging it in for 4 hours here in central Alaska.
Tedonlin150
46
11-21-2011 10:45 AM
14
10-13-2003 08:19 PM
wheels
16
11-15-2002 10:46 AM
