Nv4500 cross post need a bit of help on master and slave replacement part numbers
Old Sep 18, 2009 | 11:10 PM
roxxx's Avatar
I knew it was going but hoped for the best. I think my master and or my slave have started to really go . I put the south bend up grade clutch and fly wheel and new clutch fork and pivot ball from Dodge wheeew price on that sucked . Anyways South bend suggested putting the washer behind the pivot-ball which i have done before. plus there is a weep on my fire wall ,
Just wondering were oh were is the best and cheapest place to pick the whole master slave kit up And if nothing else a part number would rock
Thank you
Old Sep 19, 2009 | 09:29 AM
Billut's Avatar
I used South Bend's hydraulics for 94+ trucks (since this is when the NV45 fits behind the Cummins). I can dig that part # later Sunday. I made a wedge wooden mount so that the reservoir would hang level on the firewall, and voila!
Looking at your sig.: what's a Pats Drive shaft?
Old Sep 19, 2009 | 10:19 AM
roxxx's Avatar
Pats drive shaft They make drive shafts Balancing and all related stuff they use spicer parts so i kinda tend to use them I think they are A national chain store they are part of the gear center group
Old Sep 20, 2009 | 09:26 PM
deerslayer1979's Avatar
I looked into this when I replaced it on my truck. I used the OEM master and slave assembly for a 92 W350. Works like I thought it should, no problems with fitment or operation. BTW when I called around to the local parts houses they told me the part # for the 1st gen and 2nd gen were the same. Hope this helps.
DS79
Old Sep 20, 2009 | 09:44 PM
Billut's Avatar
not exactly the same though: on the 1st gen I've seen (I could be wrong), the hose is on the side of the reservoir, on 2nd gen it is at the bottom. Granted, it is a detail...
Old Sep 20, 2009 | 09:53 PM
I couldn't tell you to be honest, the only thing I can remember being different is that the 2nd gen ones had bleed screws on them. For me the price difference wasn't to bad. I hink the OEM stuff cost me something like $40 more. Worth it IMO to know it was OEM quality.
DS79
Old Sep 20, 2009 | 10:44 PM
roxxx's Avatar
`I will see if i can get oem not to sure but I was wondering if the oem will be strong enough with the after market clutch ?
Old Sep 21, 2009 | 07:06 AM
Bob Beauchaine's Avatar
When I did my NV swap it would not go into gear while the engine was running. I talked with Peter at SB and he said hydraulics - clutch and clutch MC. I didn't listen and pulled the tranny, clutch and flywheel to measure it against the old setup. As a result I did a lot of extra work - the problem was hydraulics. Replacing the hydraulics with spendy Dodge parts $300+ solved my problem. The total parts clutch MC, slave cyl and all parts comes as a complete package.
Bob
Old Sep 21, 2009 | 08:18 AM
roxxx's Avatar
Bob
Thank you Bob
i figured the old one would do well on the old setup but as soon as i tryed to engage on the first startup with the new stuff , I figured it was the slave or master , One thing I am worried about on the new Aftermarket master/slave is the throw ,Is it the same ?
Old Sep 21, 2009 | 08:52 AM
Please post what you find out about the new setup. I am hoping that some one would put together an aftermarket replacment for the Dodge setup. My money would be on SBC.
Bob
NO_SPRK
Nov 1, 2009 10:38 PM
deerslayer1979
Jul 21, 2008 07:14 PM
Heeler00
Feb 18, 2004 01:52 PM
