No Overdrive when its hot out.....
Old Jul 29, 2008 | 09:55 PM
HIGHfinance97's Avatar
started driving around town and it was fine, after awhile in town I got to a stop light and I see the wait to start and water in fuel light come on, as I start to drive the lights start to flicker more and more as speed increases every time after a stop it would do this except when its not acting up.
eventually it would go into OD and stay for a bit then come out and the lights will start to flicker again
when it would finally go into OD, if I hit the OD button or step on the pedal and kick it out of OD the lights would come on and it will not go in for awhile
when I drove it at night and its cool out its fine... does not skip a beat
Old Jul 30, 2008 | 09:59 AM
truckdweld's Avatar
I have the exact same problem. Really edit you off when it is hot out. Cruising on the freeway is fine just don't slow done or those lights turn on. I sure hope somebody can help us out with this problem.
Old Jul 30, 2008 | 05:14 PM
Sound like PCM trouble. Clean the connector at the PCM.
Old Jul 30, 2008 | 07:05 PM
Will do...thanks Dave
Old Jul 31, 2008 | 05:54 PM
Don't expect miracles, you may be buying a PCM.
Old Aug 2, 2008 | 02:17 PM
TJE's Avatar
TJE
mine has been acting up as of late....what is a PCM, and where is it?
Thanx, Tony
Old Aug 2, 2008 | 02:27 PM
Thanx, Tony
Power Control Module
Old Aug 14, 2008 | 08:38 PM
Cleaned the connections and it still does it....
got any leads on a PCM??? here is the Part numbers
53008911
56027568
R56027568
whosdunit
Feb 16, 2019 04:07 PM
Strjock81
16
Dec 12, 2007 09:53 AM
abc4yew
101
Jul 14, 2007 01:39 PM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
