New Pitman Arm
New Pitman Arm
Long story short I leveled my truck, and now it doesn't turn worth a bean. Will a drop pitman arm give me a little more travel? I think they're longer as well as lower. Where Do I get one, and how do I know how much?
THANKS!
THANKS!
Unless it's untaxed, then it's red.
Please share more details! What leveling kit did you do? 2" front lift? I'm about to order alcans, he said the stock pittman arm might work, but recomended a 2" drop. I think skyjacker has them for around $45
drag
those are supposed to prevent bump steer, as the suspension collapses, pulling and pushing the tie rod, another option is a spacer block over the steering knuckle, i think i got mine from procomp, it brings the arm up 4".
Ok, here's what I did. Springs are junk, didn't replace them, just made shackles and spring hangers that are 2" longer. I would think that the truck would sit at the right height, but the stock shocks are almost fully extended now, and the pitman doesn't appear to be lining up as it should, and I can't turn worth a bean.
you need to get the adjustable drag link from rough country I think. also their kit that raises the top of the knuckle as well. A drop pitman arm puts more stress on the steering box and frame. Its relatively expensive if I remember. The ultimate solution is to go to crossover steering.
I have heard that you cannot do crossover steering without at least 4" of lift, which I do not have, and do not plan on adding. Thanks though, i will look into rough country!
Clane
06-02-2012 03:31 PM
edd209
13
08-07-2010 11:55 PM
BigDan
07-08-2006 11:04 PM
royalnine
07-18-2004 08:56 PM
