New to 1st gen, white smoke no power
Old Sep 26, 2016 | 09:26 AM
Brooktrout's Avatar
Hey all, got a 93 2wd. Had for about 3 weeks and there's a lot of white smoke and not much power. I knew previous owner and he used for farm truck. He had a leaky pump on back side. Had someone remove pump and fix gasket on lower side against the motor where there is two torx screws. That's where I came into play. I bought it, got it home and white smoke like crazy, no power. I cleaned injectors to best of my knowledge. Changed fuel filter, and oil cause the oil level was rising due to fuel in oil. Coolant level hasnt dropped at all so I don't think it's an issue there. Suppose timing way off when pump got pulled. Looking for some help.
Old Sep 26, 2016 | 10:49 AM
j.fonder's Avatar
fuel in the oil could be 2 things.
1. lift pump leaking fuel into the crankcase (most likely)
2. front seal in injection pump leaking into the timing case and subsequently into the crankcase. (less likely)
i would address this issue first and then move from there. if it still persists, i would suspect air infiltration(most likely) or faulty injection pump(less likely)
92GhostRyder
Sep 16, 2018 12:02 PM
pulltilbroke
Apr 10, 2009 02:08 PM
BlackSheep5
Nov 27, 2006 07:52 PM
tobyw
Feb 15, 2005 11:48 AM
dhe9
Nov 14, 2003 07:31 AM
