New 1st gen owner need a little help with a couple issues.. pictures
Old 12-04-2017, 03:28 PM
Morsel's Avatar
So it looks like (see pictures) with the key on I have power to the heater blower motor. I would assume this means the ignition switch is working properly and power is making it's way to the blower motor. It would appear it is the blower motor that is faulty? Any thoughts before I rip it out?
Attached Thumbnails New 1st gen owner need a little help with a couple issues.. pictures-img_0628.jpeg   New 1st gen owner need a little help with a couple issues.. pictures-img_0627.jpeg
Old 12-04-2017, 03:49 PM
MrFusion's Avatar
I agree that that spare tire holder is a complete PITA! So I did something better. I can't take credit for the idea but this is what I did.
https://www.dieseltruckresource.com/...ch-2-a-327734/
Old 12-04-2017, 04:21 PM
Morsel's Avatar
WOW nice work!
That mod might be in my near future!
MrFusion (12-04-2017)
Old 12-15-2018, 06:25 PM
truckerick's Avatar
If your ignition switch is flaky it could cause the blower motor to not work as well as not providing a good sense voltage to the voltage regulator. Do your power windows work with the key on? The power windows and the A/C Heater blower come off the same section of the ignition switch. SO if both don't work then your ignition switch is likely bad.
The VR sense and other engine controls come off a separate section of the Ignition switch.
The radio and other accessories come off a third section of the Ignition switch and finally the starter is activated by the 4th section of the ignition switch.
Do you have an FSM for your truck? I have one for the 89 D350 and a 92 Ramcharger. If you don't have the FSM with wiring diagrams I can provide you with a link to mine via a Personal Message.
Edwin
Hi guys and gals,
I just bought a 1993 D250 and the power windows and blower don't work . The strangest thing is when I touch the power window down switch , all the red lights in the Cummins Turbo Diesel warning light panel turn on . Those lights also turn on when the heater is in any position except off . Is this because of a bad ignition switch ?
Old 12-15-2018, 11:43 PM
Received 1,332 Likes on 862 Posts
Originally Posted by truckerick
Hi guys and gals,
Sounds l more like a short or bad ground somewhere. Power is back feeding, and/or looking for a way to ground is my guess.
nonrev (12-16-2018)
Old 12-16-2018, 07:03 AM
truckerick's Avatar
Yeah that was my first guess until I found this thread
Old 01-05-2019, 07:58 PM
alwaysonDTR
Alwaysworking's Avatar
I would also check the heater fan resistor
209trucker
09-28-2013 07:06 PM
farmboy56
03-01-2011 10:15 PM
92GhostRyder
08-11-2010 08:31 AM
leper
01-21-2008 09:37 PM
Shark1007
07-13-2006 11:56 PM
Quick Reply: New 1st gen owner need a little help with a couple issues.. pictures
