in need of help lost with iut my baby
Old Feb 13, 2006 | 01:42 AM
wreckere022002's Avatar
Exclamation in need of help lost with iut my baby
ok yall in need of help was driving my 93 dully with a 5.9 turbo in it when she shut down the other morning she dident so much as fart at me i filled her up the night before drove for about 4 hours and parked her she was running fine started her up let her warm up for about 10 min or so prob should have waited longer but she was driveing fine when i leaned into the gas a bit she started to pick up speed and then just shut down no sighn of any thing she still turns over and the on board is not saying a thing just 12 and 55 from what i am told is hi and bye cracked the most forward fuel line and there is fuel sitin on the injector i have no idea at what could be the matter with her if yall could give me some ideas of things to check and on some accounts on how to check them i would be very thankful to each and every person even the smallest thing might help me right now thanks
oh and this seems like a killer site so far wish i would have found it years ago
Old Feb 13, 2006 | 06:33 AM
G1625S's Avatar
Hello and welcome to DTR! There are two wires going to your injector pump. One is higher up and toward the back (firewall). This wire controls the shutdown solenoid on the pump. Sometimes the 'ol Cummins rattles them loose (usually just a spade connector) and everything shuts down--just like when you turn the key off. There should be at least 8-9 volts present there with the key in the 'run' position. Check that wire first. My guess is that it came off. In case you've never messed with it before, the injection pump is on the driver side of the engine, toward the front. Find the mess of 6 injection lines on the back of the pump and look directly above that area for the shutdown solenoid and the potentially offending wire. Check there and get back to us---we'll get 'ya rattlin again!
greg
Old Feb 13, 2006 | 07:38 PM
If that doesn't cure it, try changing the fuel filter.
Old Feb 14, 2006 | 07:58 AM
ruquik's Avatar
i fixed mine for $1.50, only after i spent $150 on new fuel lines from Cummins that i can't return, bastards. I found mopar type spade connectors from a place like federated, or napa work awesome and look stock, not too mention are well protected in the plastic shrouding. I guess anything will work but i like to look stock. Replace both connectors, the one on the backof the pump and the one on the side.
Old Feb 15, 2006 | 12:01 PM
Thumbs up will try
ok ill try that tonight i have replaced the fuel filter on the side of the eng there is only one correct would have done it last night but was told if i touch the truck last night i die
Old Feb 15, 2006 | 03:30 PM
That is the only fuel filter.
Old Feb 15, 2006 | 03:55 PM
timb's Avatar
Hey Wanna, remember a few week's ago mine pulled air from somewhere and did the same thing, just getting into the throttle and she shut down.had to bleed all six injectors and she fired up.took all of five minutes on the side of the highway.If it is not the solenoid wires, then bleed the injectors at the head three at a time and see if that gets her shaking. by the way, I still havent found the source of the air in the lines.
Old Feb 15, 2006 | 09:03 PM
Smile she runs again
ok she runs 4 now ibeeding the injectors worked if anyone knows how air got in the system i would love to know thank yall for all your help i am off for a test run let yall know how she does
Tank_66
May 19, 2008 09:45 PM
andrew2910
Jun 24, 2007 09:43 AM
wreckere022002
Feb 16, 2006 08:45 AM
JKM
Jun 9, 2005 09:00 PM
