Need Help Fast! Bypassing The PCM
Old Jul 4, 2012 | 12:46 PM
1972RedNeck's Avatar
I think my PCM might be going bad (or I am going crazy). I have found THIS.
Do I hook the regulator to the 2 terminals that are about 1 1/2" apart? does the top go to the top regulator pin and the bottom go to the other pin?
How do I make my A/C function without the PCM?
Old Jul 4, 2012 | 03:11 PM
I would prefer to by pass the PCM completely.
Old Jul 4, 2012 | 03:12 PM
simplysmn's Avatar
OK just wanted to offer it
Old Jul 4, 2012 | 03:18 PM
Yes, the external regulator connects to the two small terminals.
Pull the plug off the AC relay and run a jumper wire between the load terminals in the plug.
00 PAU
Sent from my Paranoid Android HD2 using Tapatalk 2.
Old Jul 4, 2012 | 05:31 PM
I just did this. I took 12 volt keyed power and ran it to the top pin on the regulator and one pin on the alternator. I ran the other pin on the regulator to the remaining pin on the alternator. Nothing.
How can I test to see if my alternator is good?
Old Jul 4, 2012 | 09:14 PM
Is the regulator screwed to something metal? It needs to be grounded to work.
00 PAU
Old Jul 4, 2012 | 09:33 PM
Yes it is. Would it help if I run a ground wire directly to it?
Bruce M
Dec 17, 2013 02:59 PM
c-bass
Dec 8, 2012 03:10 PM
Big Perm
Dec 18, 2007 08:44 PM
robert78.5
Dec 26, 2006 10:52 PM
adidasman23
Dec 22, 2006 02:43 PM
