Bypassing a bad PCM.
Old Aug 16, 2007 | 04:53 PM
Bruce M's Avatar
How do you bypass a bad PCM on a 91.5 with auto trans to go into overdrive?
Old Aug 16, 2007 | 05:18 PM
Ground the wire that's NOT blue.
Old Dec 17, 2013 | 02:59 PM
master6789338's Avatar
pcm bypass
on my 93 first gen with auto trans, so far after the pcm went bad I got the speedo working by grounding the speed sensor ground wire and running a power wire with a resistor inline to the brown and tan 8 volt feed wire near the pcm plug to the speed sensor and also goes to the crank sensor.speedo works. I took care of the not charging problem with a separate wire directly from alternator to the battery and used an external voltage regulator with the power to the regulator on it's own relay. I also have the o/d on a switch and am going to use a pressure switch on the trans so I can also have it go into o/d automaticaly. I am still working on the tach hook up.
1972RedNeck
Jul 4, 2012 09:33 PM
Big Perm
Dec 18, 2007 08:44 PM
Bham Ram
Mar 29, 2007 05:00 PM
robert78.5
Dec 26, 2006 10:52 PM
adidasman23
Dec 22, 2006 02:43 PM
