need help fast
Old Aug 6, 2007 | 01:54 PM
93beater's Avatar
need help fast
ok the plug on the drain on your fuel filter, is that mandiotry to have for your truck to run, i was told it could just be the water in fuel censor, and in that case i could get by without it, while changing my filter yesterday 1 of the wires ripped out, so if you could give me some info on where i can get a new little drainer thing w/ the plug and if a can run my truck! thanks
Old Aug 6, 2007 | 01:58 PM
Chrisreyn's Avatar
Its a factory( Dodge Dealer) item and willset you back about 46$ here in Topeka! The truck can run just fine without it being plugged in, and you can actually buy filters that dont even have the hole for teh WIF sensor, which is the "official" name of the part.
I wouldnt suggest going without it, but for a short time, it shouldnt hurt anything
Old Aug 6, 2007 | 02:05 PM
93beater's Avatar
ok that makes me feel a lot better, thanks for the help!
Old Aug 6, 2007 | 07:09 PM
BearKiller's Avatar
It won't hurt a thing to leave the wires un-hooked, so long as the plastic gizmo is screwed in the bottom of the filter.
I use LS1221 Fleetgaurd; they are about twice as long, and are solid bottom, with a made-in drain-valve that stays with the filter.
Old Aug 7, 2007 | 12:04 PM
93beater's Avatar
nice do you have to move anything around to get thos to fit, and where can i get 1? how often do u change them?
Old Aug 7, 2007 | 02:17 PM
paccool's Avatar
You can order a new Water in Fuel sensor at Genos for about $22. Just looked to be sure they still carry 'em.
Old Aug 8, 2007 | 05:48 PM
BearKiller's Avatar
Nothing has to be moved to fit the CORRECTION = FS1221.
I buy them in bulk from Scheid's; but, any Cummins place should have them, as Fleetgaurd is Cummins filter brand-name.
I just watch for an unexplained drop in fuel pressure and change according to what I find.
Old Aug 9, 2007 | 01:41 PM
BearKiller's Avatar
Let me amend my statement; as, I was getting my LS1220 Makita Miter Saw mixed up with my FS1221 Fleetgaurd fuel filters.
Too many numbers going around in my head.
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
wwm
Feb 26, 2009 08:37 PM
Sam Turner2
Jan 11, 2008 03:32 PM
trik396
Mar 14, 2007 07:57 AM
