Water Seperator Question
My fuel filter/water seperator has got the place to plug in the two wires at the top of the fuel filter, but I think there is a place to plug two at the bottom that is missing, because I have two wires there with nothing to plug them in to. I get an occasional water in fuel light blinking, and was wondering if it is real without those wires hooked up. Also, where might one find the bottom part without paying a fortune. Maybe that makes a little sense.
The two wires at the top are for the fuel heater.
It sounds like you have a filter with no provision for a WIF sensor, or the wires got ripped off it. You can get the right filter and a WIF sensor from Cummins or from Geno's Garage.
Just use Fleetgaurd LS1221, with none of that wires-hanging mess on them, twice as long, and fit like a glove.
If the WIF light is coming on, with the plug not connected, moisture, or something, is shorting across the connections in the loose plug, just like water makes the circuit in a working water-in-fuel sensor.
