Water Fuel Seperator Question
Old Dec 15, 2008 | 04:52 PM
nbaggett89's Avatar
Hello,
I am rebuilding my cummins engine to stick in my CC frame and as I was going through it, I bought a new water/fuel filter for it. As I was going to install it, I noticed that the guy who had this truck before me had put a different filter on the engine than what it is supposed to be. The one he had one there had no port at the bottom for the sensor to hook up, but my new filter does and it looks like if I don't put anything there, then the fuel will just drain out the bottom of the filter. Could someone send me some pics of how it is supposed to look all hooked up so that I can hope and try to find the wiring that is supposed to hook up to my fuel filter? Thanks!
Old Dec 15, 2008 | 05:12 PM
Ace's Avatar
Ace
I would just go with the larger FS1221 filter and forget about the WIF sensor. All the WIF sensor does is trigger a dash light through the PCM.
Old Dec 15, 2008 | 05:16 PM
nbaggett89's Avatar
Yeah I might end up doing that, but the problem is I already have the filter I just don't know what the hookup looks like...
Old Dec 15, 2008 | 05:31 PM
M1Lover's Avatar
Sounds like you're missing some parts, as its just a couple wires and a rubber plug-looking dealie (like my technical description?). I'd sell your filter here and get the one Ace recommends. I wouldn't try to "restore" the WIF sensor... H.
Old Dec 15, 2008 | 05:52 PM
nbaggett89's Avatar
Ok well it looks like I have all of the wiring because there is a plug that drops down right by where the filter goes. It looks like I'm onyly missing the part that goes between the bottom of the filter and this plug. Would it really be that hard to find this part or order it from cummins? If so, where do I buy the other recommended filter from?
Old Dec 15, 2008 | 05:56 PM
The WIF sensor is about $25, you can get it from Cummins or online from Geno's Garage.
Cummins (or any truck shop that carries Fleetguard) can get you the FS1221 filter.
Old Dec 15, 2008 | 06:05 PM
nbaggett89's Avatar
Ok thanks, also, is there a way to order cummins parts online through their website, because if there is I cannot find it.
Old Dec 15, 2008 | 06:06 PM
Nope, gotta call your local Cummins distributor.
Old Dec 15, 2008 | 06:56 PM
nbaggett89's Avatar
Oh I see, and how do I find out where or who that is?
Old Dec 15, 2008 | 07:17 PM
http://powersouth.cummins.com/wps/portal/powersouth
DodgeFreak
Dec 2, 2011 04:07 PM
gcliburn
Aug 9, 2007 01:46 PM
TON4FUN
13
Mar 30, 2003 08:55 PM
yomitch
Nov 18, 2002 01:33 AM
