Need Help Asap No Overdrive
Old Oct 28, 2008 | 02:39 PM
ol' 93 12 valve's Avatar
Exclamation Need Help Asap No Overdrive
My 91.5 auto isnt shifting into overdrive. I thought it was a low voltage problem because i wasnt sure the truck was charging but i checked it and its charging at about 14.5? What are things to check for.
I need my truck back on the road by thursday night have a 5 hour drive to make. Any help is appreciated
thanks
Old Oct 28, 2008 | 02:49 PM
Tuckerdee's Avatar
Is your speedometer and odometer working. If the Vehicle speed sensor isn't working, then the OD won't work either.
Old Oct 28, 2008 | 03:01 PM
yah there both working. the last time i drove the truck it felt like it would kick into overdrive going down hill with just the slightest throttle but then kick back out.
Old Oct 28, 2008 | 03:03 PM
Tuckerdee's Avatar
Then it sounds like your throttle position sensor needs adjusting. There's a procedure in the sticky section for doing this. The issue of the TPS is why many auto guys have changed over to the in-cab potentiometer...also in the stickies.
Old Oct 28, 2008 | 05:38 PM
You may find this thread helpful.
https://www.dieseltruckresource.com/...d.php?t=211628
Read carefully, as it discusses both '91.5's like yours as well as the later trucks.
Old Oct 28, 2008 | 05:56 PM
I already have the potentiometer.
Old Oct 29, 2008 | 05:01 PM
Figured out the problem. The battery was draining its self. I put a volt meter on it and the battery was losing volts. It was one i bought from autozone, i put a good battery in it and did the same test with the battery termanls on the battery and it didnt drop any took it for a test drive and overdrive worked.
horselady
Jan 27, 2009 12:01 AM
stock03
Sep 30, 2008 09:03 PM
72demon440
Apr 27, 2007 10:45 PM
99goatman
May 21, 2003 08:37 AM
crossy
Nov 8, 2002 05:05 AM
