need help with ASA intake quick!
hi
the new asa just came in - im in the process of mounting it and cannot find the hole for the support bracket, im confused, where the hell does the support bolt onto the fender
any pictures or instructions would be great
please dont think im an idiot
oh and i should block the holes in the fender so no junk comes through and gets on my filter right?
thanks justin
thanks justin
hi
thanks justin
thanks justin
thanks
i hear much more turbo, it sounds sick
although the turbo doesnt kick in till 3/4 throttle, i know im gonna order the 16cm housing friday and the 3200 spring from pdr diesel
brandon the holes i was talking about are the four holes used to mount the "stock" air filter box, look under the ride drivers side fender above the wheel you will see 4 nuts, i took these out like the instructions told me to, all they do is hold the stock air box assembly down
justin
justin
I took a 4 to 5 inch rubber adapter for plastic drain pipe I purchased at the Hardware store and adapted it to my stock (drilled out) airbox and K&N filter. Works slick as Deer guts on a doorknob.
And yes, it sounds "sick" (that is "cool" to us Old Guys)
oilcan64 patience patience youngun lol. Just can't wait to hear the baby run huh. Did your filter make her run better? When you get the 3200 spring and the 16cm housing you will be grinning for sure. Hows the trans doing? Good luck with it.
