need a clutch
Old Oct 5, 2007 | 12:28 AM
knelson351's Avatar
need a clutch
i'm looking for a clutch for my 93 d250... has cummins 5.9L w/ getrag 5 spd.
my trans went out and i want to put a new clutch since im gonna have it out... any one know where i can get a new one???
thanks
-kris
Old Oct 5, 2007 | 12:37 AM
RuralCruiser007's Avatar
South Bend Clutch.
If you look around on here you will see what is available and what they think of each product. South Bend Clutch is what is most recomended.
Old Oct 5, 2007 | 12:48 AM
CTD03's Avatar
valair clutches
www.valairinc.com
i am running one and its awsome it holds every thing i like about it and the price is good
most people will tell you to go with southbend
so you have 2 opitions the choice is up to
what do you plan on doing with the truck????
Old Oct 5, 2007 | 12:07 PM
apwatson50's Avatar
The valair clutch is what Southbend sells as they're stock replacement clutch, also most other parts stores that i've found. Peter was able to get me the best price though.
Old Oct 5, 2007 | 12:24 PM
rbrettctd's Avatar
Avoid the 12" southbend...bad news apparently. The center can break out of it....guess Ill find out soon enough. lol
Old Oct 5, 2007 | 01:53 PM
Magnum Salvage's Avatar
Just ordered a new Sach's which is the OEM replacement. Ordered from Peter at Southbend. Make sure you deal with Peter when you call there. I had to deal with him cause someone else there told me they didn't have what I wanted. Clutch alone was $150.00. Best deal I found. A clutch disc, pressure plate, throwout bearing and bronze input bushing also comes in a kit for $475.00. Add flywheel for around $600.00 total. I had my flywheel and pressure plate cut down. Good luck.
Old Oct 5, 2007 | 09:21 PM
1stGen545's Avatar
The Sach's is good for a lot of power ( 300-350 hp) I like them.
Old Oct 8, 2007 | 01:59 PM
PapeCAT's Avatar
did you know that the sachs was over-engineered and designed specifically for our application by chrysler...
Old Oct 8, 2007 | 03:16 PM
dieselJon's Avatar
What are your goals hp/tq wise? And do you tow, pull, drag or just play around?
The Sachs are a good all around clutch. Holds great! I had pulled with it 3 times at the local fair and it had 160,xxx miles that included pulling livestock up until about 2 years ago.
Old Oct 8, 2007 | 06:07 PM
SmokemS's Avatar
blackclouddiesel.com is the place for a nice southbend
Old Oct 8, 2007 | 06:44 PM
dieselJon's Avatar
And stacks
angelfire7
Nov 7, 2007 09:48 AM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
