napa seal or cummins oem
Old Sep 23, 2010 | 11:28 AM
Dlowkes7's Avatar
can i just go to my local napa and get a rear main seal. or is it that much better to drive an hour to the cummins store to get the seal kit for tomorrow night?
Old Sep 23, 2010 | 12:29 PM
jesussaves's Avatar
i m in the same situation, i have to dive 1.5hrs to pick up cummins parts but for something like a rear main seal I think its worth it.
Old Sep 23, 2010 | 01:08 PM
YOREL's Avatar
The cummins seals are worth the time and money. I believe they are teflon impregnated as the other brands are just neoprene or some such. If it was an easy seal to get to I would say yes go with a cheapy if you must, but what costs more, the effort to get a real cummins seal or doing the job twice?? Just did my rear main when I rebuilt the auto tranny and the seal kit was about $65 or so IIRC.
Old Sep 23, 2010 | 01:17 PM
67HotRod's Avatar
I wish we had thought ahead and got a cummins seal instead of the leaking napa seal I now have....
Old Sep 23, 2010 | 01:37 PM
artieb's Avatar
I have read the stickie and what are good # front and rear seals?
Old Sep 23, 2010 | 04:24 PM
YOREL's Avatar
These are the seal kit numbers. The kit includes the seal, a metal intallation ring, and a plastic protective sleeve to slide the seal over the end of the crank. Front #3937111 $32.95. Rear #3934486 $69.55. The big secret with these seals is that they must be installed dry. No oil!!! just squeaky clean with brake cleaner on the crank surface.
Old Sep 23, 2010 | 06:40 PM
kensmachine's Avatar
If your crank shaft is badly groved Cummins has a repair kit that has a oversize seal and a sleave for the shaft.ken
Old Sep 23, 2010 | 10:15 PM
93Fury's Avatar
I just put in a NAPA seal because the Cummins one I got was damaged before it was in my possesion. Looking at them side by side there was absolutely no difference except color and the fact that the NAPA one didn't say Cummins on it. This was the front seal.
Old Sep 24, 2010 | 01:03 PM
Dlowkes7's Avatar
Cummins quoted me $92.50 for the rear kit last night. I ordered it so i can just get my truck back on the road asap.
P/N # for the rear he gave me was #3934486
Old Sep 24, 2010 | 10:55 PM
sdseva's Avatar
make sure you check your crank surface before you order too...i just ordered one before i looked and my crank surface is badly grooved, i tried seating it at a different depth but it started leaking already! and i took my time
SKATERHAULER
Oct 2, 2013 06:34 AM
Shaun Cockran
May 8, 2012 05:52 PM
BAJA MAN
Nov 21, 2006 05:49 PM
dieseljerk
Jul 8, 2004 07:23 AM
SSV1761982
Jun 24, 2004 11:15 AM
