What turbo ?
What turbo ?
I know some of you feel this may be repetitive, but here are the mods I plan on doing, and I am asking for suggestions on a turbo for this application. I currently have a stock turbo on it with many miles, so its due to be replaced. I was thinknig of a HX35W but wasnt sure what down pipe is needed as I dont think they are the same from what I have stock.
M&H M2 fuel pin
25 HP injectors
3200 GSK
1/8 Timing bump
What turbo and dwon pipe will be best for this?
TIA
M&H M2 fuel pin
25 HP injectors
3200 GSK
1/8 Timing bump
TIA
HE351cw hands down. (stock turbo off of 04.5-07 dodge) You'd love it with your manual transmission, it spools dang quick and cools well. Good for at least 40 lbs of boost. I loved mine. It has a 4" outlet on it so then you will have a true full 4" exhaust .
Only the 12V motors had a sperate elbow on a HX35. The 24V motors had a one piece backplate and elbow assembly. A 2nd Gen downpipe can be used if attention is paid to routing and some clearancing may be required around the pinchweld at the lower cab area.
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
