My overdrive works!!
I finally got my OD to work. The problem was the ECM?, I found it under the battery, thanks to this forum. It was not bolted down and was banging around in the fender well. I removed it from the fender well and disconnected the wire plug. I found that the connections where extremely dirty. I cleaned the connections with some electrical contact spray from Lowes. Put it back together and mounted it of the inner fender well and my OD started to work. Thanks to all on this forum for your suggestions and help.
Hey Old Hippy, ... sounds like you headed off a bunch of problems as there are several other functions in the evil domain of our PCMs. Mine's been trouble-free so far but I'll do as you did just to stay ahead of things. It's the first time I've seen you so here's my "Welcome to the Forum", ..
72demon440
Apr 27, 2007 10:45 PM
AggieJustin
Jan 25, 2003 10:46 PM
