More turbo questions.....
Old Oct 26, 2007 | 08:35 PM
CaptainChrysler's Avatar
I just got a WH1C that has some compressor problems. I am going to put the exhaust housing on my rig. I though I read somewhere about drilling out the wastgate passage to a larger size. And drilling it through the divider too? I would like to do this before I put it on.
Also, am I missing something or where did the wastgate hose hook to?
One more thing is it possible to use the cast elbow and a second gen down pipe? I am willing to do some fab/welding?
Old Oct 26, 2007 | 11:17 PM
Ok, so I have been reading and thinking. Is it a bad idea or not even possible to put a WH1C compressor housing on my H1C? I am looking to get rid of the ol' barky bark when I shift. I have heard you can cut your own slots.
Old Oct 27, 2007 | 08:02 AM
G1625S's Avatar
The elbow and downpipe won't fit without expensive fabbing. Not worth the trouble, IMO. The compressor housing will fit your H1C. You'll have to swap the wheel as well. The threads are reverse and you'll need and in/lbs torque wrench that will read in reverse to do it right. Map slots will not cure bark. The slots cure the compressor surge that occurs when you're into the loud pedal at low RPMs.
Old Oct 27, 2007 | 08:35 AM
Just curious about whats so different on the exhaust.
Old Oct 27, 2007 | 11:19 AM
rbrettctd's Avatar
2nd gens have a LOT more room behind the turbo for downpipes. Ours have to turn straight down, as 2nds go at an angle. Just wont work too nice.
Old Oct 27, 2007 | 01:52 PM
dpuckett's Avatar
G1625S- Isnt bark the same as surge?
Captain Chrysler- What issues are you having with your H1C? I have a couple housings and wheels if you need them. PM me for details.
Daniel
Old Oct 27, 2007 | 03:31 PM
Bark is a "woofwoofwoof" when you jump off the accelerator at high boost. Surge is a "chchchchchch" at moderate to high load at low RPM. They are similar in that the turbo is producing more pressure than the airflow through the turbo will support.
Old Oct 28, 2007 | 06:22 PM
Well after I actually looked at my DP and a second gen one, I realized there was no way. I guess I will just have to wait for the 4", come on xmas bonus!!
I got the 12cmWG on and I am pleased, now I want the compressor upgrade.
Old Oct 28, 2007 | 06:34 PM
Another thing I read on a few sites that a 1 ton has a larger compressor. I measured mine to see for sure and it has a 54mm wheel. I am fairly sure it is the factory turbo.
92smokin blacky
Mar 19, 2010 11:39 AM
pistazie
ABDTR #5
Apr 30, 2009 08:16 AM
gman07
Apr 15, 2006 08:32 PM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
