does more boost = more power?
Old Dec 20, 2003 | 09:09 PM
j's Avatar
j
i'm going to purchase a turbo master for my truck soon. after trying to pass a few people going up the hill yesterday, i had a thought. will going from 20psi to about 28-30 give me more power?
Old Dec 20, 2003 | 09:14 PM
jrs_dodge_diesel's Avatar
Re:does more boost = more power?
Yes and no. More boost does equal more power but to a certain point. You have to be able to add more fuel as more air is rammed in the cylinders.
Only if you have the fuel to make the power. What the TurboMaster will do for you is allow you to use the power longer before the EGT gets too high. When you put the TM on, tune it for the lowest temp using your pyro gauge. If you're not having high EGT problems on a long pull, you don't have enough fuel yet. ;D
Old Dec 20, 2003 | 11:11 PM
j's Avatar
j
well i definately have high egt probs on hills, so i'm guessing i have a need for more air. thanks.
Old Dec 21, 2003 | 10:26 AM
Racer57's Avatar
Gearing down when towing 30' 5ver will also help alot when going up hill. Do not try to pull steep in OD. You need more RPM's which will keep boost up.
G1625S
May 14, 2012 10:31 AM
sCreamin400
25
May 10, 2010 10:14 PM
Towmaster101
Apr 5, 2008 04:01 PM
aggieredneck12
17
Jun 24, 2007 06:12 PM
Bradtothebone
Apr 10, 2003 08:28 AM
