maxed pump timing and towing question.....
Old Oct 19, 2008 | 07:47 PM
pwrtripls1's Avatar
With my injection pump shoved to the head what is my limiting factor with towing? Can I still tow as much as I want as long as I watch my EGT and keep them in a safe range? Or is there some other factor besides just EGT when it comes to towing with an advanced pump.
Old Oct 20, 2008 | 08:16 PM
pwrtripls1's Avatar
Anyone have an idea on what the limiting factor is?
Old Oct 20, 2008 | 09:00 PM
Onemoparnut's Avatar
If I am correct the timing bump will lower your egt
Old Oct 20, 2008 | 09:40 PM
A timing bump will always lower egt and increase performance. But shoving it to the head. I dont know.
Old Oct 20, 2008 | 09:49 PM
CaptainChrysler's Avatar
With more timing you are pushing more heat into the pistons. It lowers the EGT, but the heat is still made, and kept inside the engine. I would not hold it at 1250 for too long while towing with it "to the head".
Old Oct 21, 2008 | 06:23 PM
You sure don't want to lug it with a lot of timing, that's a good way to crack pistons.
Old Oct 22, 2008 | 11:02 AM
I was refering to 1250* EGT.
Incase I wasn't very clear on that.
Old Oct 22, 2008 | 07:20 PM
charger 69's Avatar
Do you consider 1/8" a safe amount??
Old Oct 23, 2008 | 12:01 AM
Tron's Avatar
If I understood right, more timing with upgrades=more combustion pressure and like wanna said lugging is not good. I also though you had more risk of blowning the head gasket
Old Oct 23, 2008 | 05:32 PM
Yes, I would not be concerned about 1/8".
Brendan
Mar 15, 2010 02:59 PM
1stgenjake
Jun 16, 2009 04:45 PM
tomgreentwin
May 24, 2006 08:50 AM
pwrtripls1
May 28, 2005 04:00 PM
