Indexing throttle
Old Oct 23, 2008 | 02:24 PM
89f150's Avatar
Indexing throttle
Ok well i indexed the throttle when i put the gov. spring in and when i did that i turned the idle all the way out and it was still to high. so i moved it one spline and turnid the idle screw back up and now it seems to have less power??? Any ideas idk what to do
Old Oct 23, 2008 | 04:35 PM
unixcowboy's Avatar
When you re-index the throttle you don't get FULL throttle travel - even if your pedal is on the floor.
Have someone mash the pedal while you watch the throttle. Then adjust the CABLE so the throttle lever touches - or almost touches - the IP body at wide open.
I had to bend the pedal lever where the cable attaches ... Almost 1"
Old Oct 23, 2008 | 05:22 PM
Switching the ball stud and the return spring locations on the pump lever works wonders for throttle travel.
Old Oct 23, 2008 | 07:02 PM
89f150's Avatar
I will have to do that when I get my injectoes in
Old Oct 23, 2008 | 07:41 PM
unixcowboy's Avatar
Forgot about that, wanna...
I still had to bend my pedal tho.
TrkEnvy
Oct 27, 2012 06:35 PM
apwcu
Aug 29, 2011 12:33 AM
bradshaw106
Sep 26, 2008 05:31 PM
Alwaysworking
Aug 24, 2008 11:26 PM
G1625S
Mar 7, 2006 06:17 PM
