Fuel Injectors for MPG
Old Oct 22, 2008 | 05:08 PM
MoparMarv's Avatar
I'm thinking its about time to freshen up the injectors on the truck. Any recommended injectors for with a good balance between power and economy? I typically get 20 mpg plus and would like to stay that way. I don't have any more mods planned other than whats below for the time being. Is there something other than stock injectors I should take a look at? Or just stick with stock rebuilds?
Old Oct 22, 2008 | 05:34 PM
BOSCH 190's or like 40 horsers off of ebay. DDP3's.....they are all relatively clean running injectors. Good power adders. Thats if you want the both. otherwise rebuild your stockers i'd say.
Old Oct 22, 2008 | 05:43 PM
You won't do better than what you have if mileage is your goal.
Old Oct 22, 2008 | 05:51 PM
EatMySmoke's Avatar
I have my original stock injectors and still get 20+mpg. My truck also has 445,000 miles on it in case that helps you decide.
Dawson
Old Oct 22, 2008 | 06:13 PM
rebuild em. lol
Old Oct 22, 2008 | 06:43 PM
KD93's Avatar
So what about for my heap? I'm IC'd so I don't have the bigger injectors. I'm looking for the same thing, mild power increase but still economical. Probably 190's too, right?
Old Oct 22, 2008 | 07:15 PM
Yea 190's would work nicely. They dont run very smokey. which means fuel mileage +++
Old Oct 22, 2008 | 07:28 PM
MoparMarv's Avatar
On these 190's
Where is the best deals on these? what should I expect to pay?
Also with towing how are they. I have a car trailer 10,000GVW capacity that I tow from time to time. Is that going to be a problem with my current mods?
Old Oct 22, 2008 | 09:57 PM
ilovemy12valve's Avatar
20mpg?
Well I just got my 92 w 250 and I have heard a bunch of people saying they get 20mpg. Is that interstate driving or just normal everyday driving?? I average about 16. Would my bfg 305-70-16s have anything to do with 4mpg less? Thanks guys this club is awesome
Old Oct 22, 2008 | 10:11 PM
MoparMarv's Avatar
I can say tires have an effect on MPG. When i bought the truck I had BFG commercial T/A's 235/85R16 stock size on there. I would get 20 plus average no problems in the summer with the best ever being just under 24mpg. Winter I would be just under 20mpg and would have a hard time breaking that. Now I have Alcoas with BFG All terrains in 265/75 R16. Mileage just doesn't seem to be as great as it used to be. and now with the injector/boost leak(still trouble shooting) its really in the tank. I think any SRW 1st gen with a 5spd should be able to break 20mpg on the hwy. Keep it at 1700-1900rpms on the hwy thats what works best for me.
Those 305/70R16's are a wide tire and probally have a ton of rolling resistance. something taller and skinnier would probally help. 285/75 R16 maybe a good comprimise. Staying out of thin pedal helps as well.
Old Oct 23, 2008 | 09:24 AM
unixcowboy's Avatar
Don't forget --
Going to a larger tire usually means it's also taller -
That means your EFFECTIVE gearing will be different. taller tires will get slightly better hiway mileage but the engine will work harder to get the truck moving making the in town mileage suffer....
Also, your odo will be off by the difference in the the tire heights.
Stock 235/85R16's are ~ 31.72 tall
My 285/75R16's are wider but also 32.83 tall.
That means I need to multiply my odo reading by 1.035 to get the true mileage traveled. Doesn't sound like much but 400 mi REALLY = 414 miles...
If you used 21.5 gal at 400 mi = 18.6mpg
But at 414 mi = 19.256 mpg
Old Oct 23, 2008 | 10:39 AM
Ace's Avatar
Ace
Another angle on effective gearing to consider is your engine speed at cruise vs. wind resistance. The mpg gain going from 70mph down to 65mph can significant if you can match your top gear cruise rpm to somewhere around 1800 at 65mph. That's where the 12v is the most fuel efficient and drag starts becoming less of a factor.
Old Oct 23, 2008 | 12:01 PM
samiam4's Avatar
On someone whom gets low mileage measured in their truck...
Have you replaced the Odometer gears? I'd bet he's missing a tooth and it works, but is inaccurate. I went from 14 to 20 when I replaced my gears.
Michael
Old Oct 23, 2008 | 01:11 PM
Ace's Avatar
Ace
A good way to check your speedo accuracy is with the interstate mile markers. GPS works too.
Old Oct 23, 2008 | 07:50 PM
IRoss's Avatar
do the speedo and the odometer use a different set of gears? I've often seen my odo stick a little, but the speedo always works while this occurs...
richard
26
Sep 6, 2007 01:35 PM
KRB
May 20, 2007 06:20 PM
bigfish5
Sep 19, 2006 12:56 AM
BIGOKIE
Jul 21, 2004 05:53 PM
